Porch Ceilings With Beadboard Look - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 03:18 PM   #1
Rewards Points: 73
Porch ceilings with beadboard look
Hi...
I am looking into redoing two porch ceilings with a beadboard look. I am curious what advice people might have in order to guide me to something that will last and is not too expensive and preferably saving me some work. I guess there are sheets, roughly 4x8', but figure I can also do beadboard tongue/groove but that seems like quite a bit more work.
I was hoping to get something prepainted but might be just outta luck. The only ones I have found are MDF. Im assuming because of moisture exposure, even though they are painted, its a bad idea using MDF on an outside porch. Am I assuming incorrectly? PVC seems off the chart for cost.
Any other ideas or have I covered most options?
Lastly, the first porch is a front porch about 5ftx30ft. The second is a screened in porch, more square about 13ftx12ft.
Thanks in advance to anyone who can help me out.
Werner
whoppr is offline   Reply With Quote
Old 04-15-2012, 04:27 PM   #2
DIY staff
Rewards Points: 7,174
For outside use look into 3/8" thick fir bead board--not the thin 1/4" pine---you may need to check at a real lumber yard---
It installs quickly--with almost zero waste---4x8 sheets look ,well like cheap paneling--
Skip the MDF--that is only good indoors.
3/4" car siding also looks good if the narrow traditional bead board is not the look you are after.
Old 04-16-2012, 06:00 PM   #3
Rewards Points: 73
Im assuming the fir is not pre-painted. If not, its probably easier to paint before putting up.
Do you use screws or are nails OK with a nail gun?
For the long porch, in your opinion is it better to put the beadboard the length of the porch (like a hardwood floor) and stagger the boards or go width-wise and cut them all at around 5ft and go that way? Its probably a matter of asthetics but figured I would ask.
Old 04-16-2012, 09:33 PM   #4
Rewards Points: 12,808
Why not beaded vinyl soffit with vinyl cove moulding.
Never needs painting, no visable nails, a cleaning once in a while with a pressure washers is all it needs.
Comes in 12' 6" lengths.
Old 04-17-2012, 06:27 PM   #5
Rewards Points: 73
I looked briefly for soffit at Lowes but couldnt find it. I must have been looking in the wrong spot. How does it look afterwards?
Old 04-19-2012, 04:47 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
That's what I would do........ and never need to paint it again.
Refinishing Beadboard porch ceiling ? cellophane Painting 10 02-12-2014 09:05 AM
beadboard panel installation (ceilings) t_mccann Remodeling 12 01-05-2013 01:42 AM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 12:31 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
