Pocket Door In Load Bearing Wall - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 06:05 AM   #16
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by aleciadooley View Post
I was up in the attic today. When the insulation is pulled away you can see the support beam from the top of the wall. The plaster ceilings but up to it. The joists in the attic overlap above the 2 x 4 beam. In the area where I plan to put the pocket door they are 2 x 6's. Then off to the side there are 2 x 6's attached to 2 x 4's. Not sure if this last info is relevant or not.
I'm not sure I can understand the description, however, the general rule is(majority of times) that the a center wall of a home is the main load bearing wall.In order to make adjustments to create wider openings, the ceilings on both sides of that wall, should be braced/shored, in order to support the two ceilings, which are generally supported, by that center wall.
Dependent on the number of floors above that wall, there is greater load bearing down.
As stated, since you feel, and it appears, that the wall us a load bearing one, I strongly advise that the re-framing portion of the project be performed by a professional - framing carpenter, remodeling contractor, or GC.
The contractor would install the pocket door frame, at the same time the wall is framed in with the new header.
I list those kinds of contractors for a reason.
That is because a "carpenter", is not necessarily experienced as a "framing carpenter".
A "Contractor", may be more experienced with drywall, painting, & minor trim carpentry, but know virtually nothing about structural framing.
So be careful who you bring in, to do the work, make sure that they understand, know, and possess the experience to do such a job, and are not just "yes-ing" & "uh-huh-ing"....you.
- Build Well -
loadbearing wall , pocket door
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 09:33 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
