Pocket Door Help - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 02:14 PM   #1
pocket door help
hi I would like to install a new pocket door in a regular door frame. The problem im facing is that I have a wall that is made up of 2x2's ( mid 50's built) and Im not sure if I have to re frame the wall or could I get away with just doing only part of the wall to fit the pocket door. The reason for the pocket door is needing for space/bathroom remodel.
cmnelson74 is offline   Reply With Quote
Old 03-06-2009, 02:19 PM   #2
Remodeling Contractor
A pocket door needs a minimum 2 X 4 wall. The wall is removed for a distance twice your door opening. The pocket door kit will contain the framing members (except the header materials) to rebuild the wall.
Considering Pocket Entry Door at top of stairs snsdiy Remodeling 6 01-06-2009 06:39 AM
Pocket Door Framing and installation res17nn9 Carpentry 4 11-04-2008 04:42 AM
hidden t-v pocket sticker Building & Construction 1 10-07-2008 11:01 AM
pocket door coming off track jimmy21 Building & Construction 6 10-06-2008 02:28 PM
How to remove interior sliding (pocket) door Horst Remodeling 7 12-13-2007 12:13 AM
