Plywood Cemented - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2014, 09:36 PM   #1
Plywood cemented
A contractor put Portland cement over about 3 inches of plywood which should have been cut at weeps screed above the foundation. Stucco was done.. Says it will be ok since he put flashing tape over it...Wondering how bad is this? Will the wood rot... Should I insist on redo, cut the plywood at weeps creed and cement below? Tx..
Johnnyhome is offline   Reply With Quote
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 01:05 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 10:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
