Plywood To Cement - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 11:58 AM   #1
plywood to cement
what size nail to use nailing 3/4 plywood to ceament,how manny nails per 4-8 sheet
john223 is offline   Reply With Quote
Old 04-15-2012, 12:42 PM   #2
Rewards Points: 12,830
Untreated wood should never be attached directly to concrete.
What is it your really trying to do?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
kj6887 (04-17-2012), woodworkbykirk (04-15-2012)
Old 04-15-2012, 03:11 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
i would be using a powder actuated tool or a hammer drill and tapcons
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
kj6887 (04-17-2012)
Old 04-17-2012, 12:39 AM   #4
Drywall contractor
Rewards Points: 1,070
I'm agreeing with joecaption that it must absolutely be pressure treated. Is this possibly for flooring?? If so, you may get a better response in the flooring section of this site. I would recommend using adhesive along with whatever fastener you use....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
