Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-13-2008, 06:00 PM   #16
plugging a hole in polyurethane?
Just a follow-up on my project. I drilled holes on bottom of the pan, filled the voids and patched with a product called Duramax 4040. I then filled the pan with water and let stand 72 hours. No leak. I have another question. I'm going to put in sliding glass shower doors, Is it necessary to put blocking behind on each side where the end rails fasten to the tiled walls? I read where it only says how to drill into the tile and install screws. The backerboard isn't up yet. Thanks.
rolls831 is offline   Reply With Quote
Old 11-13-2008, 06:19 PM   #17
Man of many hats
wrangler's Avatar
When you say 'end rails' I assume you are refering to the side rails. If so. then no, you do not need to block for them. The actual weight of the sliders are carried by the top rail wich rest on the side rails. The screws are basically just keeping the side rails from simply falling over. If you think to might want grab bars now or down the road, now would be the time to block for them. Same goes for a seat if you think you might need one of those someday as well.
Good job on fixing your pan problem!
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 11-14-2008, 12:24 PM   #18
Thanks for the info. The blocks are in for the grab bars, Thanks to information from this forum. On with the project.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
