Hi Everyone,
I'm remodeling a bathroom and I'd like to use the same type of casing I have throughout my 1930's Cape Cod. The door/window trim is done in two pieces. I've found plenty of the outer type, but I'm having a hard time identifying the flat piece. The piece is 2 3/4" x 1/2", the piece used on the top is all flat and the pieces used on the sides have a slight bevel to the inside edge. Does anybody know what this is called and if it's likely that I'd be able to find it somewhere in the correct size or would I have to pay to have it milled?
Thanks Much,
SJ
Thanks Much,
SJ
