Plaster Repair Questions - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 03:57 PM   #1
FlyingHammer
Plaster repair questions
Where can I find a good web site or set of instructions for repairing plaster walls? It appears my walls are some sort of hard plaster applied over a 1st generation drywall, not the typical plaster and lath.
The 1960's era house I'm working on had a very serious water problem. There was standing water in the basement for several months before I bought it, and lots of mold due to the high humidity. I already fixed the water problems and cleaned up most of the mold problems, but now I have to fix the deteriorated walls. The majority of the damage seems to be water related - mostly from humidity condensing on the windows and running down the interior walls. How do I go about fixing these problems without replacing whole walls? The plaster is mostly still intact but there are some soft spots I'm going to have to cut out and replace.
Problem #2 - I also see a lot of peeling paint and "spider veins" in the ceilings. I assume this was also caused by the humidity. Is there anything special I need to do with this, or can I just scrape it off, putty, and repaint?
Here's some photos:
Plaster repair questions-1.jpg   Plaster repair questions-2.jpg   Plaster repair questions-3.jpg   Plaster repair questions-4.jpg
FlyingHammer is offline   Reply With Quote
Old 02-15-2012, 09:03 PM   #2
Rewards Points: 978
thats pretty bad. i would hire a professional
federer is offline   Reply With Quote
Old 02-16-2012, 05:27 AM   #3
FlyingHammer
Isn't this a DIY forum? I have more time than money, so I prefer to give it a shot myself first.
Old 02-16-2012, 05:42 AM   #4
Stay-at-home GC
First things first, Lead Paint?
Get yourself a test kit at your favorite HW store and check EACH LAYER of paint, not just the last one.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-16-2012, 07:07 AM   #5
Rewards Points: 14,300
How old is this house?
I'd be more inclined to think it's paster over tile board. It was common to see this before drywall came out. It was faster then applying all that lath.
I would not hesatate a min. to remove all of that old plaster.
Reasons being.
There's going to be trapped moisture behind those walls now.
Would give you the chance to up grade and or replace any wet insulation.
Allow you to up grade wiring or add more outlets.
If ballon constrution you would have access to install blocking at the top and bottom of the wall to add fire safety and stop air flow inside the walls.
Old 02-16-2012, 10:20 PM   #6
Registered User
Rewards Points: 526
"Where can I find a good web site or set of instructions for repairing plaster walls?"------
Cruise around here: http://www.plaster-wall-ceiling-solu...questions.html
Read it all: http://www.nps.gov/history/hps/tps/briefs/brief21.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
FlyingHammer (02-19-2012)
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 08:28 PM
plaster ceiling repair. patricias Drywall & Plaster 4 04-10-2011 12:35 PM
tile directly on bare veneer plaster? bubbler Kitchen & Bath Remodeling 6 03-03-2011 08:29 PM
Porch Repair Project (pics) and questions vendejp Carpentry 12 10-05-2007 09:30 PM
