Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-12-2009, 09:13 PM   #1
Angry
Plaster and Lathe Walls
I peeled wallpaper off one of our rooms and have discovered that some of the walls are the old plaster and lathe walls. There were two layers of paint that came off in places with the wallpaper. Should I remove all the paint from the walls, or just try and repair where the paint peeled off? I realize that this paint is lead based and know about the safety precautions, just want to know if I should peel all the paint off on these walls or patch?
The joys of an old home!
AnnaL0602 is offline   Reply With Quote
Old 09-13-2009, 08:12 AM   #2
Peel/scrape off any loose paint, then skim coat with drywall compound. That will smooth things out. CAREFULLY clean everything up, it is almost surely lead based paint.
Old 09-13-2009, 10:54 AM   #3
Thanks, that will work for me..the less work I have to do the better. Good news is that I think I started on the oldest room in the house, which I think was the original living room. The other rooms will be pieces of cake (lol).
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Plaster walls and Lathe Keith in Connecticut Remodeling 5 01-03-2008 08:36 PM
How strong is plaster & lathe Keith in Connecticut General Discussion 6 08-24-2007 11:46 AM
replacing lathe and plaster eager2lern Building & Construction 2 12-04-2006 01:52 PM
