Plaster - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 09:15 PM   #1
Rewards Points: 22
plaster
I am redoing my house and some rooms have some kind of drywall(think it's called blue board, 12" wide strips) nailed to the walls and then a 3/8" or so layer of plaster. I need to patch some holes where I took a wall out. What is the best way to patch these?
Can I just patch some drywall in the spaces and then tape and mud them? Or do I have to use plaster? Also there is some spots that just need a "skim coat", can I just use mud on these or do I need to use plaster?
Never delt with plaster before so if I am going to need to any tips will be appreciated. Thanks.
ponch37300 is offline   Reply With Quote
Old 02-12-2009, 05:59 AM   #2
Blue board is what is used under a modern plaster finish. Yes, it can be patched with standard drywall and mud.
Old 02-12-2009, 07:27 AM   #3
Rewards Points: 22
Thanks bill. I was hoping I could just use regular mud since I've never used plaster before.
Old 02-12-2009, 10:54 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
The stuff in 12" wide strips is called rock lath. It is pretty much like drywall, but was used as a base to plaster over. You can use 3/8 or even 1/2" drywall to patch in and cover it with drywall compound. It's usually easier to shim your patch to match the surface of your plaster and then tape the joint and finish like you would drywall.
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Plaster replacement lburele Building & Construction 1 04-29-2007 09:48 AM
Plaster removal decision Sarai Remodeling 2 09-08-2006 03:15 PM
