Piece Of Horizontal Wood Through Studs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-01-2006, 03:52 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
piece of horizontal wood through studs?
I have put studs up and have noticed other work that there is a piece of horizontal wood approximately half way up.
Do I need to put that piece of horizontal 2 X 4 between my studs?
How far up from the bottom plate should it go?
And why would I need to do that? My guess is that it makes the structure more stable and strong?
yummy mummy is offline   Reply With Quote
Old 11-01-2006, 04:25 PM   #2
only for inner walls
horizontal wood between studs is only required for inner wall generally to give more strength in my opinion... not required for outer walls... I remember seeing somewhere said it also blocks fire.... not sure about that though... you can do those later on when you have those unused pieces here or there, just add them rather than throwing them away...
KUIPORNG is offline   Reply With Quote
Old 11-01-2006, 04:58 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No need to install these.
What you may have seen could be for a number of other reasons;
Over 8 foot high walls-used for ridgidity, Fire blocking in some applications, backing for handrails or other type of hardware to attach screws to, backing for certain wood trim to nail to, attachment points for plumbing lines, etc...
Again, nothing you should have to worry about.
- Build Well -
Old 11-01-2006, 07:13 PM   #4
Master Craftsman
Big Dave's Avatar
I agree with Atlantic. Really no need unless the wall is over 9'
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 11-01-2006, 10:11 PM   #5
Thanks for all the information.
I just saved myself some work.
Old 11-01-2006, 10:26 PM   #6
i always thought it helped prevent warping and twisting, but i guess on interior you dont have to worry as much
Justin1635 is offline   Reply With Quote
Old 11-06-2006, 09:26 PM   #7
Don't know what you called them here, but where I come from they were called dwangs, haven't seen one in years.
Sportbilly is offline   Reply With Quote
Old 11-06-2006, 09:42 PM   #8
sportbilly
never heard them being called dwangs.
Old 11-08-2006, 11:47 AM   #9
renovations
Yeah, as in "Do I have to put those dwang pieces in?"
Bonus is offline   Reply With Quote
Old 11-08-2006, 02:01 PM   #10
Send a message via Skype™ to iGotNoTime
I was laughing when I actually found that term! I consider myself educated now, but don't know if it is a term I would be proud to have knowledge of on Jeopardy.
http://en.wikipedia.org/wiki/Dwang
Good call Sportbilly!
iGotNoTime is offline   Reply With Quote
Old 11-08-2006, 10:48 PM   #11
bonus
You are funny. I am still laughing
Old 11-23-2006, 09:34 PM   #12
Smokin Joe
jombres's Avatar
What did the building inspector say to the builder when he failed him for his structure not being up to code....?
"Dwang IT!"
hahahaha
man this term had to come from down south!!
jombres is offline   Reply With Quote
Old 11-23-2006, 09:55 PM   #13
jombres
Great job, judging BBQs.
I always do charcoal.
No better flavour.
Old 11-24-2006, 08:33 AM   #14
Smokin Joe
jombres's Avatar
No better flavour.
oh yeah....gas is for sissies....lol
I have a steel, wood-fired BBQ Pit. The offset Texas Style with the firebox on one side and a little lower than the main cooking chamber.
I told the manufacturer he ought to make t-shirts that say...."Real Men Cook with Wood" on the front, with a picture of the smoker on the back. He didnt get it....Didnt think it was funny. I guess he had never heard of that saying "Real Men Dont Eat Quiche" so the play on words was lost on him. At any rate, I used charcoal with wood chips for my first several years, then moved up to a wood fired smoker. its a lot of work, but the taste is so good, its almost illegal....
A lot of the BBQ competitors at these contests I go to, use either charcoal and wood, or wood alone (hardwood fireplace logs, like oak, cherry, hickory, maple, pecan, etc) to fire up their cookers.
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
finishing a basement- metal tracks & wood studs sweep the leg johnny Building & Construction 4 03-09-2007 04:05 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
