Picture Window J Channel - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 12:20 AM   #1
Picture window J channel
I just finished installing 4 picture windows, 2 are separated by a 2x4 between them. The house is brick.
These windows have a integral J channel all around. It is about 5/8 wide about 1" forward of the nailing strip. I would like to fill the air space behind it. The easiest way would be to remove it. It has a groove at the window casement, It looks like it would break off pretty easy. Is it an option to remove it or do I have to fill it with foam or fiberglass?
larrylwill is offline   Reply With Quote
Old 06-12-2009, 06:46 AM   #2
The J channel is for installing siding later, if you will not be installing siding, it can be cut off fairly easily. Score it deeply with a utility knife and it will break off at the score.
Old 06-12-2009, 10:13 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
on some windows it taps in a groove and can be pried out
carefull cutting vinyl with a knife im sure bill agrees
Tom Struble is offline   Reply With Quote
Old 06-12-2009, 12:23 PM   #4
I was hopping that was the case.
Thank you
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
picture window flashing and 2x12 problem DangerMouse Building & Construction 3 08-02-2008 02:27 PM
picture window matjone Carpentry 4 01-03-2008 07:04 PM
Window casings around window with integrated J channel? sandyman720 Building & Construction 11 10-02-2007 01:15 AM
