Patio Privacy Screening - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 10:43 PM   #1
Rewards Points: 4,796
Patio privacy screening
If anyone has any good ideas for this let me know. This is a patio on the ground floor of a condo. You can see the wide open "window" space and the exterior is a stucco-like material (don't know my siding options very well.) The HOA says no nails or screws may pierce the siding, if any screening is added.
What is desired is a privacy sort of screen, so air can still circulate and you can see out to a certain extent, but other condos or people walking in the courtyard can't see in very well. Also, need a system to hold it in place. I'm thinking some sort of "ZipWall" sort of setup, but don't have anything specific in mind. Of course we could always attach to the rail with U bolts or something like that at the bottom.
Looking for a) the type of screening and b) the attachment method, thanks.
jeffnc is offline   Reply With Quote
Old 04-08-2014, 12:17 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
have you walked around the condo site to see if anyone else has something similar to what you are looking for?
gonna be difficult to install something without fasteners that would stand up to wind loads.
wish I had a solution for you, good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-08-2014, 12:24 PM   #3
PoleCat's Avatar
Rewards Points: 1,652
Maybe a picture from the courtyard perspective will get some juices flowing.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 04-08-2014, 12:33 PM   #4
No other screens in the area.
Don't have the courtyard perspective, but you'd just be looking at the rectangular hole.
My idea right now is to use some sort of pole such as a shower pole, that can be twisted to expand, and pressure 2 pieces of wood, 1 on top and 1 on bottom, that could be slotted to hold spline. This would then be temporary, and obviously very easy to take down when moving.
Perhaps something like this, although at this price it doesn't seem super high quality.
http://www.plowhearth.com/7-pack-of-...urtain-rod.htm
Three of those - 1 on each end and 1 in the middle - ought to be enough to hold the frame in place I would think. Since the patio is a closed space, wind shouldn't affect it much. In other words, when wind blows, it will be blowing primarily past the screen sideways, and not through it. And this is a courtyard, not an open field.
Edit: these prices seem more like it
http://www.plowhearth.com/66-120-sta...unt-joiner.htm
Old 04-08-2014, 12:45 PM   #5
PoleCat's Avatar
You are talking about regular window type screen material?
Old 04-08-2014, 01:01 PM   #6
Yes, I'm looking at Phifer SunTex right now.
Old 04-08-2014, 01:07 PM   #7
PoleCat's Avatar
How large is the opening? I would be inclined to make a wood frame with spline molding that fits snug between the floor and ceiling. Put the top in position then push/tap the bottom out until it is tight in the opening. Maybe two or three panels to make up the width.
Old 04-08-2014, 05:38 PM   #8
96" high by 158" wide. I don't think your idea would work since there is so little room to work with, with the handrail there.
Old 04-08-2014, 05:48 PM   #9
kwikfishron's Avatar
Rewards Points: 1,002
What about something like this? You said no attachment to the siding but what about the beam?
kwikfishron is offline   Reply With Quote
Old 04-08-2014, 05:50 PM   #10
Unfortunately, the "beam" is actually just the same stucco material. Can't attach to anything except the hand rail (and that would be with U bolts or something, not directly drilling into it.)
Old 04-08-2014, 06:30 PM   #11
The only thing I can think of for an attachment point and have it look nice would be to have metal fabricated to cradle the beam and the stem wall below. You've been handed a tall order to hang something from nothing.
Old 04-08-2014, 06:33 PM   #12
Rewards Points: 2,648
I would think you would be better off building a fully self supported structure (i.e. a 4 x 4 post at either end, with a foot plate and gusset, and a 158" long 2x6 top and bottom to tie it together). Its not really much lumber when you think about it -- cedar would look nice. Then you would have a 2x6 top and bottom to mount the shade rollers to. I think you have the right idea on the material --- I have similar material 72% blocking over top of my deck --- does a good job of blocking the sun but you can still see through it. I would go to any local awning place and ask what they have for a good price on 3 shade rollers about 48" wide, with open material as you describe.
SPS-1 is offline   Reply With Quote
Old 04-08-2014, 06:35 PM   #13
Actually, on second look, it looks like in the link you posted, the "Palisade" model might have an option for posting to a post system, which might attach to the cement floor. I might be able to attach there, and it looks like that's the only attachment for that model and that option. I'll call them in the morning and ask - hard to tell exactly from the brochure.
Old 04-08-2014, 06:39 PM   #14
Any picture link to give me a better idea of what you're talking about?
Old 04-08-2014, 06:55 PM   #15
I don't have a real picture, but hear is a quick sketch of what I mean.
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
patio screening stmpr55 Building & Construction 2 03-21-2012 07:02 AM
screening in an existing patio jamesbalog Building & Construction 1 03-04-2011 11:41 AM
Patio Shade and Privacy ideas for the hot tub syndicate1 General DIY Discussions 7 07-05-2010 08:04 PM
