Patio Door Remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 11:00 PM   #1
Patio Door remodel
I have a standard 6'x8' sliding patio door that I want to swap out for a new french door. I got lucky and found a great deal on a new door. Problem is the jam does not fit. I need some info on building or buying a remodel jam. Is this something that I can build myself? The door I purchased is a prehung door but does not have a remodel jam. Help. Wife wants this in NOW..... One of the doors is fixed as well. I would really like to make this door live as well.
azguy is offline   Reply With Quote
Old 02-20-2008, 12:12 AM   #2
PRO Siding Windows Roofs
Remodel Jamb? As in to fit inside the old door? They aren't too popular and I would never use one. Just take out the old door and install the new one
PKHI is offline   Reply With Quote
Old 02-24-2008, 04:15 PM   #3
Windows Plus
should be able to use exisiting jamb. finish off with interior casing.
Kenny K is offline   Reply With Quote
Old 02-26-2008, 07:49 PM   #4
"Wife wants this in NOW!"
Tell her that you want it to look good, so she will have to be patient. Sure, that will work.
Use a reciprocating saw to cut the screws or nails, whichever is holding the sliding door. As stated previously, I wouldn't use a remodel jam. Simply assure that the opening is the correct size and shim to fit.
Handyman50 is offline   Reply With Quote
Old 02-27-2008, 08:27 AM   #5
Windows Plus
that should work. new casing around frame. good to go.
Old 02-27-2008, 11:03 PM   #6
Rewards Points: 5,336
You need to be a little more specific on what you're doing. Are you dealing with the rough opening or the frame of the old door? Is the jamb too wide or too high?
Post a picture.
Ron
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
