Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-16-2011, 12:29 PM   #1
parging large exterior block fireplace chimney
I have read different ways of parging and wonder if the cement and sand mixture can be tinted to match the siding on our home. Also, is this coating going to be affected by Michigan's cold and damp weather. Living on a lake gives us a lot of wind driven rain. The block chimney of old and not smooth as it was originally built.
mike works is offline   Reply With Quote
Old 10-17-2011, 10:27 AM   #2
Concrete & Masonry
I would recommend buying colored mortar by the bag and just adding sand and water. If you have more than one batch to mix, it's the most accurate way to keep the color uniform. As for it lasting, it shouldn't be a problem as long as the chimney is flashed & capped well, and isn't currently taking water on.
jomama45 is offline   Reply With Quote
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General Discussion 1 01-29-2011 10:26 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
fireplace and chimney top rebuild??? syborg Building & Construction 18 01-16-2010 03:58 PM
