P Trap - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 07:21 PM   #1
p trap
what is the best way to remove the cap on top of the p trap in a basement shower drain. the trap is below ground!!!
firetruck12 is offline   Reply With Quote
Old 08-19-2013, 07:32 PM   #2
DIY staff
Rewards Points: 7,174
Could you explain a little more clearly---what cap are you speaking of?
Is this a shower stub out sticking up through the concrete floor or did someone put a cap onto a finished shower drain?
Pictures speak a thousand words----Mike----
Old 08-19-2013, 09:31 PM   #3
sorry its the stub sticking out of the concrete!! I dug down to where the p trap is, and removed the 2 foot riser which was not glued. Thank goodness. Then there is a plastic cap on the p trap inside of the riser. Not sure how to get that cap off
Old 08-19-2013, 09:37 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
sounds like a wafer or SP cap. They are temporary caps glued for testing.
You can stab them with a screwdriver to break through it. Them carefully pry it out.
Don't worry about leaving the outer ring there. Just make sure all the plastic is removed from the inside.
Old 08-19-2013, 10:19 PM   #5
thank you very much I will be giving that a try in the morning
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 06:45 PM
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
