Outside Wall Tub Surround Vapor Barrier Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 06:01 PM   #1
Outside wall tub surround vapor barrier question
I am getting ready to install a new tub/ shower in freshly renovated bathroom (gutted, reinsulated, vapor barriered (outside walls) and partially mr dry walled) I plan on using cement backer board for a tile backer in surround. My question is should I or can I add another vapor barrier over existing full wall vapor barrier to go behind cement backer and end at tub flange? Is there a reason that I should not do this? Being an outside wall I am thinking that there should still be a full vapor barrier on said outside wall. Any input would be greatly appreciated.
shotsy is offline   Reply With Quote
Old 03-29-2010, 07:37 PM   #2
Remodeling Contractor
you need a waterproofing over the cement board, so a vapor barrier behind it makes no sense. However some inspectors will still require it. Normally we then install it, get the inspection and then remove the poly. Never have a double vapor barrier. So protect the work I would not use a poly barrier.
Old 03-29-2010, 11:34 PM   #3
OK just to make sure I am understanding you I should do the following:
-remove vapor barrier
-install cement backer right over studs and bare insulation
-apply a waterproof membrane such as kerdi
Have I understood you?
I should have maybe given a little more info in my first post sorry for that. My plan was to put up the cement board and cover with redguard; is this going to be sufficient for water proofing? Is a waterproof membrane a better way to do it? If I have a leak won't all my insulation be wrecked? I thought the idea of putting the vapor barrier behind the cement board was so if any water ever say seeped through a grout line it would make it's way back to the tub. Sorry for all the questions I just want a tub shower done right the first time that doesn't leak and doesn't give me a headache in a few years. I live in Alberta Canada and it's common practice to put vapor barrier on outside walls over fiberglass insulation.
Old 03-30-2010, 08:05 AM   #4
your inspector will require the vapor barrier in that climate.
Use Kerdi... far better than the redguard which is latex based and if water gets in it re-emulsifies.
Tags
shower , surround , tub surround , vapor barrier
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Wall prep question medicdave Painting 9 06-16-2008 08:42 AM
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
