Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-21-2010, 04:44 PM   #1
Outdoor speaker installation on vinyl siding
We want to install two outdoor speakers on to our vinyl
sided home. How can we do this since there is nothing solid
behind the vinyl? Thank you!
Sherri C. is offline   Reply With Quote
Old 06-21-2010, 07:42 PM   #2
firehawkmph's Avatar
Sherri,
What's under your vinyl, foam or something not structural I presume. You could remove a few pieces of the vinyl, very easy to do, cut out a couple of squares of your sheathing between two studs, and replace it with the same thickness plywood. Fasten it good with screws or nails, caulk all the way around and then install a light mount block made for vinyl siding. You can get them at Home depot. They are plastic and have a trim ring that pops off and goes over your siding and looks like a piece of channel all the way around. You have to cut your siding around the block, leaving about a 1/4" of clearance all the way around. Here's a link for them:
http://www.dinesolbp.com/mounting_blocks_Standard.php
I am typing this on my deck as I sit her and listen to my bose speakers mounted on what else, light blocks. Nice evening....hurry and get yours up!
Mike Hawkins
firehawkmph is offline   Reply With Quote
Vinyl siding installation question Branden Building & Construction 2 06-01-2010 01:17 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-14-2009 12:16 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
