-   -   orbital sander (http://www.diychatroom.com/f15/orbital-sander-111200/)
wengang1 07-18-2011 05:28 PM
orbital sander
I just bought an orbital sander, my first, and it is held by the palm from right behind the motor rahter than by a handle.
If I bear down on it even a little, it appears to stop spinning. I can't tell if that's actually the case or an illusion, since the vibration still makes it blurry, but I can see at the least that it speeds up when I all but remove all pressure.
The user manual says it has a mechanism to slow it down when it is NOT in contact with a sanding surface, but this seems to be the opposite behavior.
Normal? The brand is DeWalt.
Thanks.
Bud Cline 07-18-2011 06:15 PM
All electric motors slow under a load.:)
mickey cassiba 07-18-2011 06:33 PM
Thanks.
The sander you describe(a model number would be useful)should not spin when it is not in contact with the work. If it is new, I would take it to a DeWalt service center. If it is not under warranty remove the sanding pad(three screws) and look at the clear rubber belt that goes around the fan/counterweight and the small fixed pulley. If it is loose or shows signs of wear, replace it.
HTH
