Options For Closing Off Window In Kitchen - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 01:08 PM   #1
Options for closing off window in kitchen
Hi All,
I want to close off a window in a cement block house. Please see the attached picture of an outside view of the window. The question is should I block it up and then stucco over the cement blocks or is there some other method that might be easier.
Thanks in advance for you help
Regards
Gary
GandGTarr is offline   Reply With Quote
Old 02-03-2014, 08:25 PM   #2
do not see any pics.
landar is offline   Reply With Quote
Old 02-03-2014, 09:07 PM   #3
Thanks, it is fixed know.
Old 02-03-2014, 11:01 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,294
Block and parge is going to the best finish and most uniform.
Old 02-04-2014, 03:51 AM   #5
Rewards Points: 14,026
Why do you want to get rid of the opening?
No mention of where you live in your profile, or what "look" would be best for your area.
Any insulation in the walls?
There are ways to spray foam inside the block or add insulation to the outside of the building before you cover it up.
Old 02-04-2014, 07:50 AM   #6
The reason I want to close it off is because I am creating another room on the patio which will include the location of the window as one of the walls.
Pass Through Counter Top & Window Setup Questions miamicuse Building & Construction 6 05-25-2013 08:13 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
kitchen window 7echo Remodeling 5 01-25-2009 11:15 AM
