Options For Basement Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 05:26 PM   #1
Rewards Points: 16
options for basement floor
what is my best option for basement floor? I like wood but it is not good with moiture. tile is kind of cold and not kid friendly. Carpet is high maintenance. What is your experience?
Paul.le is offline   Reply With Quote
Old 01-01-2012, 08:02 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
What's there now, dirt or concrete?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-01-2012, 08:04 PM   #3
Rewards Points: 582
install heating in the floor 1st then install wood over that.....
Old 01-01-2012, 08:27 PM   #4
Rewards Points: 16
just bare concrete and some old carpet that get to go.
Old 01-01-2012, 08:28 PM   #5
Rewards Points: 16
what kind of heating are you recommending?
Old 01-01-2012, 08:32 PM   #6
Rewards Points: 582
hydronics...wirsbo in floor heating system..... just a thougth..
Old 01-04-2012, 03:48 PM   #7
Just stain the concrete
knucklehead is offline   Reply With Quote
Old 01-04-2012, 04:58 PM   #8
Rewards Points: 660
Where are you located?
What will the basement be used for?
How warm/cold is the basement?
B
Beepster is offline   Reply With Quote
Old 01-04-2012, 07:54 PM   #9
re basement floor
I've been considering same question as I'm getting bids for my basement. I visited 3 flooring places and all advised a floating floor using a laminate with an underlayment. FWIW, I'm planning on a 10 or 12 mm laminate except in the bath and I'm using tile there.
I'm exp concerned about moisture because there's a French drain in so it's obvious the previous owner had more water issues than I knew about when I bought it.
canoes is offline   Reply With Quote
Old 01-04-2012, 08:07 PM   #10
DIY staff
Rewards Points: 7,174
Seriously think about ceramic tile with area rugs---a nice look--no moisture concerns and if water happens the rugs can be quickly rolled up and sent off to the cleaners.
As a do it your self project ceramic tile can be very reasonable in cost----Mike---
Old 01-04-2012, 10:45 PM   #11
Rewards Points: 2,202
For laminate/wood/tile the floors must be flat, no dips or wow's.
For me it is low pile commercial carpet in concrete floored basements. Usually they are not flat and it costs a fair bit to flatten them. Also I find tile/laminate cold unless the floor is heated.
mae-ling is offline   Reply With Quote
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Fireplace trim options - hardwood floor joemontana16 Flooring 2 01-15-2010 04:28 PM
Need to expand hot air heat to second floor and basement what are my options rossl56 HVAC 4 01-19-2009 05:53 AM
Options for waterproofing cement shed floor YNOTDIY Flooring 4 01-19-2008 11:31 PM
heated bathroom floor options? elementx440 Building & Construction 1 02-20-2007 03:34 PM
