Opinions On Wall System Please - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 03:50 PM   #1
Rewards Points: 154
Opinions on wall system please
Hello,
I'm looking to get some opinions on finishing a room in my basement. This is going to be a room for dog grooming. The room is 1/2 underground, has a cement wall half way up on 2 sides and a 2x4 wall the rest of the way (exterior sheathing is lined with tar paper).
Not pictured in the (crude) drawings is capillary breaks under the XPS and bottom plate of the new wall as well as foam board, caulk, and insulation around the rim joists. All insulation will be roxul and drywall mold-resistant. New wall would be blu-wood with probably a PT bottom plate.
Please be critical of any errors I'm making in these ideas so I know. I Live in ON.
Option A:
It would be nice to have a built-in ledge on two walls but I'd lose a bit of R-value with the 4" exterior wall.
Option B:
Better R-value...the new wall would be insulated as would the space between the VB and new wall.
Option C:
Same as B except 2"XPS instead of poly VB.
pete0403 is offline   Reply With Quote
Old 01-23-2012, 04:02 PM   #2
Rewards Points: 2,210
NO poly vapor barrier.
Building science has lots of good info. Look around there site.
http://www.buildingscience.com/docum...lation-systems
Here is a previous thread on this topic. Good reading.
EPS or XPS
mae-ling is offline   Reply With Quote
Old 01-23-2012, 04:22 PM   #3
Rewards Points: 154
I thought it was just no poly vb for concrete...the upper 1/2 of the wall is a standard 2x4 wall.
Old 01-23-2012, 04:32 PM   #4
You are correct. Sorry confused the colors in your drawing.
Do option A with modification. build top part out to be flush with bottom part. put in minimun r20 or more up to the thickness of the new wall. Poly it properly and seal it to the concrete.
Old 01-23-2012, 06:10 PM   #5
Rewards Points: 154
Thanks. So basically option B is the way to go? Too bad I was liking the idea of the little ledge.
Is there any problem with insulation in front and behind the VB?
Old 01-25-2012, 11:29 AM   #6
Rewards Points: 154
Bumpity?
Old 01-25-2012, 05:31 PM   #7
On the wood wall you want vapor barrier on the warm side of the wall, No Vapor barrier on the concrete.
If you want the ledge put 2" strips on each stud, and bottom plate. Then use r20 insulation. seal the poly to the bottom of the wood wall and concrete joint.
So basically A with 2" strips added to studs
The Following User Says Thank You to mae-ling For This Useful Post:
pete0403 (01-30-2012)
Old 01-26-2012, 12:19 PM   #8
Rewards Points: 154
Good idea, thanks.
The Following User Says Thank You to pete0403 For This Useful Post:
mae-ling (01-26-2012)
Old 04-11-2012, 03:10 PM   #9
Rewards Points: 154
I have decided to go with option A so I have a ledge built into the wall around the outside walls of the room. It will be a handy thing to have for bottles, etc and it will be about 6-8" over the top of the counter in some spots leaving enough room for outlets (no sink, just countertop). This is a dog grooming shop.
The question is, (looking in post #1, option A). How is the best way to tie the two walls in? Place a 2x4 flat side against the existing (brown) wall at the height of the new wall and then toenail the top plate of the new wall in from above?
With the new wall against the foamboard, there will be a 1/2" gap between the top 2x4 plate and the existing wall...herein lies my problem. I'd like to avoid ripping 2x6's.
Thanks.
Old 04-12-2012, 04:32 PM   #10
To tie the top of the half-wall into the bottom of the existing wall, you'll need to put in short pieces of 2x4, laid flat, with the grain perpendicular to the wall.
One question you asked earlier was about putting VB in the middle of the insulation. The general rule is to put the VB as far towards the warm side as you can. That way, the "cold" side of the VB is as close as possible to ambient warm-side temperature, and so the water vapor is less likely to condense. The closer the VB is to the cold side, the colder that moist interior air will be when it hits the VB, and the more likely it will be that you get water in your walls.
Mohonri is offline   Reply With Quote
The Following User Says Thank You to Mohonri For This Useful Post:
pete0403 (04-14-2012)
Re-thinking my basement wall insulation system 1jumper Insulation 15 10-26-2011 03:06 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
