Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-15-2012, 07:17 PM   #1
Smile
Opening up wall and finding....
So my brother decided he wanted to connect two adjacent rooms by putting in an archway in the shared wall between the two rooms. So today I open up a section of the wall on one side and this is what I discovered. What do you guys think? is this project feasible? One wall is drywall the other room has wooden tongue-groove panel walls.
Our idea is to build in a header to tie into the rafters that come down diagonal.
federer is offline   Reply With Quote
Old 02-15-2012, 07:17 PM   #2
Old 02-15-2012, 07:20 PM   #3
and a pic of the inside behind drywall side. you can see the rafter come down between the framing studs. so the archway can only be so high.
Old 02-15-2012, 07:42 PM   #4
What is all that white stuff on the ceiling?
Looks like your working on a house around 100 years old.
And your trying to remove a supporting wall that's in the outside corner of a room.
A whole lot more involved then a modern house. Remove that diagnal support and there's nothing to stop the side sway in the walls.
Just guessing but is it ballon constrution, wooden laped siding?
Old 02-15-2012, 08:11 PM   #5
the white stuff is spray foam insulation. the house was built 1950.
what do you mean by outside corner? the diagonal support is the roof rafter that's tied into the studs in the wall framing.
Old 02-15-2012, 09:15 PM   #6
You don't cut that as well! Hello Big freaking mess of house no longer structurally sound!
Nailbags is offline   Reply With Quote
Old 02-15-2012, 09:19 PM   #7
you mean the rafter? it was already cut. thats what we discovered after we cut into the wall. what do you suggest? frame in new 2x4 studs to support the rafters?
Old 02-15-2012, 11:12 PM   #8
Yeah! and get it up to code!
Old 02-15-2012, 11:16 PM   #9
so the new stud idea would fix it right
Old 02-20-2012, 11:29 PM   #10
anyone else have input?
blank wall nightmare finding pictures, wall artifacts and decorations denemante Interior Decorating 7 07-04-2011 01:56 AM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
Finding wall studs jmfma General Discussion 8 01-03-2010 06:06 PM
Bearing Wall - Finding a Contractor imgetinold Building & Construction 1 03-23-2009 10:21 PM
Finding studs in a lath and plaster wall Oilerz Remodeling 8 03-03-2008 12:52 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
