Opening Up A Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 10:29 AM   #1
opening up a wall
Here's what I want to do. I have a 32" opening from my dining room into my living room. I'd like to put in a set of 6' French Doors in it's place. So, I obvioulsy need to open up the opening in the wall. The wall in question runs paralell with floor joists underneath, and is perpendicular to the celing joists above. Is this a load bearing wall? THere is empty attic space above. It is stick built house w/ ceiling joists and rafters. The only thing it is supporting is the c.joists.
rakuz66 is offline   Reply With Quote
Old 02-08-2010, 07:57 PM   #2
Rewards Points: 5,336
You still need to support the ceiling joists, so treat it as a load bearing wall and incorporate the correct size header into the structure. If the RO falls between floor joists, install blockng to the support beam in the basement.
Ron
Old 02-08-2010, 10:56 PM   #3
Civil Engineer
Rewards Points: 4,566
For design purposes, you need to establish the dead and live load requirements for the attic which will bed supported by your header. So you need to check the code for your area, and/or discuss with the local code enforcement officer. They should be familiar with the attic loading. Once you have established the required load capacity for the header, you design the header and the supporting posts accordingly. As noted, you want to carry the vertical load down to the basement and support the posts on a major beam, or if necessary take the load directly down to the floor and support the posts on footers.
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
New opening in masonry wall Jeepsail Building & Construction 2 01-17-2010 03:50 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
opening through party wall arise Building & Construction 13 02-16-2007 05:33 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
