Opening For Slider Too Tall.. - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 02:00 PM   #1
Opening for slider too tall..
All,
The opening for a slider that I wanted to install is about an inch too tall. Can I screw a pice of dimensional lumber (5/4) to the bottom of the header and fluch with the sheathing to attach the nailing flange at the top of my new slider?
Thanks,
Cam
CamSweet is offline   Reply With Quote
Old 03-18-2012, 02:13 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes,but don't forget you should shim the bottom up a little which may change the dimension you need,you want a little space all around the unit
Tom Struble is offline   Reply With Quote
Old 03-18-2012, 02:15 PM   #3
Rewards Points: 13,300
It should not matter if it's to tall. It's common to have a 1" gap at the top so the door and be adjusted to make it plumb and square.
I would not make it tight, just adding a piece of 3/4" should make up the gap.
Old 03-18-2012, 02:16 PM   #4
hmm i was thinking window
Old 03-18-2012, 02:20 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
The problem is that he's got nothing to nail the flange at the top to. It's typical to have a "nailer" attached to the bottom of the header.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-18-2012, 02:22 PM   #6
yes but not too tight
Widening existing laundry area door opening DavidH Remodeling 4 02-21-2012 04:54 PM
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 03:32 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 04:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 09:52 PM
