Open-Riser Staircase Help - Convert Or Rebuild? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 11:34 AM   #16
Here are some ideas we found for filling out the area under the stairs. The first five examples are closed and the others are open and would require a complete replacement of our current staircase.
Open-Riser Staircase Help - Convert or Rebuild?-living-etc-under-stair-storage.jpg   Open-Riser Staircase Help - Convert or Rebuild?-under-stairs-storage-ideas_7.jpg   Open-Riser Staircase Help - Convert or Rebuild?-under-stairs-storage-ideas_12.jpg
lohryx5 is offline   Reply With Quote
Old 06-17-2013, 11:37 AM   #17
These examples are open.
So there are a variety of options, some of which appear to work a little better with the current staircase. It's just figuring out how to work with what we have if we keep it.
Open-Riser Staircase Help - Convert or Rebuild?-hidden-under-stair-storage.jpg   Open-Riser Staircase Help - Convert or Rebuild?-img_1801a.jpg   Open-Riser Staircase Help - Convert or Rebuild?-traditional-living-room.jpg   Open-Riser Staircase Help - Convert or Rebuild?-under-stairs-storage-ideas_1.jpg
Old 06-24-2013, 11:57 AM   #18
With what I'm trying to do with my stairs in this particular case, are the Building & Construction forum the past place for it? Or should it actually be in the Remodeling forum?
If yes, can one of the mods please move it for me? Thank you!
Old 06-24-2013, 12:06 PM   #19
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
I will move it for you.
Done.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
lohryx5 (06-24-2013)
Open Staircase babsbean Carpentry 3 10-10-2011 10:19 PM
Modifying studs below staircase to open up where a closet used to be Veisner Remodeling 8 03-17-2010 04:33 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
Stairs rebuild scorpio333 Remodeling 2 05-07-2009 06:12 AM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
