Old Wood Lath For Furr Strips? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 04:48 PM   #1
old wood lath for furr strips?
I'm working on my bathroom and need to get the durock furred out 1/4". I read here that someone said paint stir sticks would work. I have a lot of long old wood lath that I saved from the demo (1929 house). Can I reuse them? They seem to be in good shape.
cantonstf is offline   Reply With Quote
Old 11-30-2012, 05:20 PM   #2
funfool's Avatar
Rewards Points: 534
Sure why not, is what they were made for in the first place.
If they are correct thickness I would use them.
funfool is offline   Reply With Quote
Old 11-30-2012, 05:20 PM   #3
Rewards Points: 13,300
Should work fine.
I'd never use paint paddles. Who would have that many paint paddles laying around?
I would use wooden lattis though.
Old 11-30-2012, 05:29 PM   #4
Good...so it doesn't matter that the lath is 83 yrs old?
Love the idea of keeping "the family" together.
Debbie
Old 11-30-2012, 05:39 PM   #5
And should I nail or screw them in?
Old 11-30-2012, 05:39 PM   #6
As long as it's not rotten.
Only need a nail at the top and bottom to hold it in place. The tile board screws will hold it tight to the stud.
Old 11-30-2012, 05:48 PM   #7
Thanks! Back to the work area
Old 11-30-2012, 11:23 PM   #8
Registered User
Rewards Points: 5,216
Be sure to check the plane of the wall (flatness), as P&L studs were usually green at install (outdoor dried rather than kiln dried). They may vary be 3/8" which the plaster thickness compensated for to be smooth and uniform surface. Use a straightedge or level across the stud's fronts, shim as required. I tape the top/bottom of the lath to the stud as the first screw (in the c.b.) may split the dry, brittle lath and it falls to the side into the cavity. Don't ask...
Gary
Old 11-30-2012, 11:38 PM   #9
Thanks everyone. I have them up... and after a little finessing, all is good
Old 01-13-2013, 11:03 AM   #10
Do you still have the lath? I'm looking for old lath (in the los angeles area) for a project I'm working on in my home.
Please contact me if you're looking to part with it.
Thanks,
Steve
El stevo is offline   Reply With Quote
Old 01-13-2013, 12:04 PM   #11
Oh Steve, we threw all those extra away. Bummer! We had tons of it, too. Good luck with your hunt.
Tags
old lath for fur strips
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
2nd Remodel project question about attic WOOD KevRU Carpentry 18 04-12-2011 01:22 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
