Old House - Can't Find Studs - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 05:53 PM   #1
Rewards Points: 103
Old house - can't find studs
I just moved into an old rental house, and can't find studs in any of the walls, interior nor exterior. From googling the subject, I understand that plaster often prevents stud finders from working.
On one particular wall, I want to hang a 50" TV. This is an interior wall, 6 feet long, between an exterior wall and an interior doorway. I cut a hole for an outlet box and reached my hand inside as far as I could reach in both directions, and don't feel anything. The wall is some kind of wood paneling, 5/8" thick. If I press my weight on the wall, I see the whole thing flexing, like there are no studs. Is it possible that the wood paneling is used instead of studs to support the roof?
In another room, I have a similar problem. It's an exterior wall, with drywall interior. Also about 6 feet long. Here, I found one stud using a strong magnet (my usual method), and the rest of the wall flexes when I lean on it. I'm not at all familiar with building practices from this time period, so I'm hoping to get some insight.
Property records show the house was built in 1928, but I'm in a back house on the property (there's a 1/2 in the street address), so it may have been built later, I'm not sure.
ebalsley is offline   Reply With Quote
Old 06-13-2014, 06:38 PM   #2
Rewards Points: 12,808
#1, If this is a rental you should not be cutting holes in a wall without the owners written permission. More then enough for an eviction.
#2, Paneling in never 5/8 thick, more likely something like T-111 siding.
If it was 5/8" it could have been mounted directly to the wall but you would have been liable for the damage to the wall when you move out.
Old 06-13-2014, 06:46 PM   #3
Gymschu's Avatar
Rewards Points: 192
I sure hope to God no one was stupid enough to support the weight of a roof with PANELING.
I'm sure the studs are in there. You just need to fine ONE and then measure 16" on center to get the general idea of where the next one is and so forth. At least that's a place to start. If you have a hole opened up, just stick a fish tape or even a wire from a coat hanger into the cavity until you hit something. You could even stick your tape measure in there to see if you hit a stud.
Houses built in the 20's were usually built very solid. They actually used 2 X 4's that were actually a full 2inches by 4inches.
Old 06-13-2014, 06:53 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Structures of that vintage are/were erected with plaster interior walls. A wood strip (lath) was nailed between two upright wood members and then cement with horse hair was applied and any number of other topical applications to complete the plastering process. There was no drywall in those days.
Wall interior studs weren't necessarily placed in any particular regular fashion in those days, so studs may not exist in any given short wall span. A stud spacing of 16" certainly was not norm back then. If anything it was 18" in the day. I also wouldn't be fishing blindly inside of a wall using a steel measuring tape or a metal coat hanger knowing that those walls could easily still contain "live" knob and tube electrical wiring.
If that is a rental then you should be getting the blessing of the owner before you go cutting holes in walls and hanging televisions from walls. Anything you do in the form of penetrating a wall could be violating the integrity of that part of the structure. A large pad of plaster could detach and drop to the floor at any time just from driving a nail or cutting a hole.
If you have already cut a hole large enough to get your arm into then you have damaged a small area of the structure. You may be sticking your neck out if you don't have something in writing from the owner allowing you to make those alterations.
XXX
Old 06-13-2014, 10:11 PM   #5
Contractor
Bad Idea with a house that old. Hit a hot knob and tube insulator once and I promise you will never make that mistake again. If you can find a stud measure 18" over to find the next, if its not at 18 go to 24". It wont be farther apart than that. Also be careful playing with old plaster walls. Break too much and watch more of it fall off.
steveinNEPA is offline   Reply With Quote
Old 06-13-2014, 10:48 PM   #6
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
If you're this new to old houses, put that tv on a stand. You have to be very very nice to plaster or it will do horrible things like crack off the lathe and fall to the floor in a giant dusty crash. Leaning on a wall and making it flex is abuse of 90 year old plaster and could get very ugly very quickly.
Use a plastic fish tape, as previously mentioned. Stop leaning on or pushing on plaster walls. The joists will be anywhere from 16 to 24 inches apart from each other.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 06-13-2014, 10:49 PM   #7
Bill Kearney
Rewards Points: 1,174
As has been suggested, and you don't want to hear it, your landlord is very unlikely to think very kindly of anyone cutting holes in the walls. That or punching through sufficient fasteners to hold up a TV.
Want a TV fixed to the wall? Buy a house. Otherwise, use the stand that came with it.
As for the walls, with a rental... all bets are off on whatever someone else might have done to the walls in the past. Without seeing them in person it's sort of pointless to guess from online postings. Besides, maybe some past renter thought it'd be clever to do X, Y or Z... like you with punching outlet holes...
STOP. Ask the landlord for help & permission.
wkearney99 is offline   Reply With Quote
Old 06-14-2014, 12:13 AM   #8
Rewards Points: 6,652
In my house. They framed 16" O/C from the Doorway and Hallway openings. That means as you stand in the opening. You go 16" from the Light switch location at the doorway and measure 16" over. Guaranteed to find a stud.
Of course not every place will be like this. Especially older places that they have retrofitted over the years. Some places are 24" or even 18" O/C.
Since you live in an addition. It was most likely originally a old porch, or part of the house. Most likely built without permits, by cousins Joe Bob & Billy Bob.
Just find a decent entertainment center, that you can have a square tube for the stand come up to support the tv. Or even better. Just place the tv on the stand. The stand we have is about the size of a four foot coffee table, and about 22" high. You could easily fit a 50" on the top shelf with no issues.
Old 06-14-2014, 10:21 AM   #9
Rewards Points: 318
Could be opening with a header and filled in without a thought to a proper wall.
Apologize to the owner, patch the hole, and cover with decorative cover such as brass register cover. Make it look good. The owner is entitled to take any repair cost out of your deposit without your permission, so you are just losing money. If you want to hang anything light, one of those tape hangers.
carpdad is offline   Reply With Quote
Old 06-29-2014, 03:27 AM   #10
Rewards Points: 103
Thanks for the comments. I'm not doing damage I can't patch. The outlet I installed was a coax, near the floor, it looks good and will be permanent.
I ended up cutting a larger hole to get a good look, and I found there are no studs for a full five feet of wall - just the paneling. I think it's much stronger than drywall, but to be safe, I slid a three foot 2x4 inside the wall and fastened the TV mount to that.
Old 06-29-2014, 07:06 AM   #11
mnp13's Avatar
Rewards Points: 512
And what did you fasten that stud to???
Michelle
Old 06-29-2014, 07:10 AM   #12
Rewards Points: 103
Nothing. The paneling will be holding the weight, the 2x4 is just there to distribute the load so I'm not relying on screw holes in the 5/8" paneling.
Old 06-29-2014, 10:00 AM   #13
mnp13's Avatar
Rewards Points: 512
Your TV is going to end up on the floor. Paneling is not designed to be load bearing, with a 2x4 behind it or not.
Michelle
Old 06-29-2014, 11:43 AM   #14
Bill Kearney
You CUT HOLES IN THE PANELING? Yet another reason to despise tenants...
If there's no studs in the whole section, just the paneling, then how do you think the weight's going to be distributed? All along whatever tiny little finishing nails that were used to secure the paneling to whatever meager edge they found for it. Those will not hold.
But hey, fortune seems to favor stupidity at times. Maybe you'll get lucky. Or maybe it'll come crashing to the floor. Had it just been drywall that would've been it. Now it'll pull the paneling down with it. So instead of just wrecking the TV it'll probably injure someone unlucky enough to be nearby.
Old 07-06-2014, 10:46 PM   #15
Rewards Points: 388
I agree with the above and hope you don't run into trouble if the landlord finds out...I know I wouldn't be happy if one of my tenants went behind my back with something like this...
5/8" seems really thick for paneling...usually it's only 1/8" or so thick...? Any pics?
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
