Ok To Stop Tile Here?? Pic* - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 11:08 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Ok to stop tile here?? Pic*
I am tiling above a new tub and usually see the tile extend passed the front of the tub and down the side a bit... The ideal situation for me would be to stop right at the edge so I can get a wood baseboard to go right to the tub without having to worry about the transition. Can I do this? Like I did in this sketchup model?
J187 is offline   Reply With Quote
Old 04-04-2009, 05:26 PM   #2
Drywall contractor
Rewards Points: 1,070
The reason for the tile extending past the edge of the tub is to allow for the "bullnose" edge pieces to cap the backerboard when it's installed as a second layer (over the drywall). It also affords some protection (waterproofing) for any water that may get past the shower curtain. Water running down the edge of the tub on plain drywall will take a toll after a period of time. It will rot the drywall AND the baseboard. You CAN install your tile as shown. I wouldn't recommend it. You culd be creating problems down the road.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-04-2009, 08:52 PM   #3
I went one row of tiles beyond the side of the tub
And then put the bullnose on
Its a good idea for water protection as stated
Old 04-04-2009, 09:35 PM   #4
J187's Avatar
Rewards Points: 516
Thanks for the input. The other obstacle with continuing down the side on that wall is that I will almost certainly have to stop at the edge on the opposite wall. The reason being that the cove is only SLIGHTLY larger than the tub on that side. Literally it is 1/2 inch to the framing and If you add the drywall it is 1", not enough to get a cut piece of bullnose in. So, thats why I was thinking just stop tile on both sides at tub's edge. If I do exten on the wall in the first pic as you guys suggest, it will not be symmetrical with the other side where i have to stop at the edge. SHould I still do it do you think?
ALso, I should mention that building out that wall is not an option because of a doorway.
Old 04-04-2009, 09:58 PM   #5
Mine stops at one end near the door
The other end extends out 1 row to the window
As luck (not planning ) would have it the wall tile stops lined up with a row of the floor tiles
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
