Ok To Set Shower Shelves With Grout Instead Of Thinset? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2013, 02:18 PM   #1
Ok to set shower shelves with grout instead of thinset?
My contractor says he's learned "a trick" from experience that it's better to use grout in place of thin-set to adhere ceramic soap dish and corner shelves to Duroc on shower walls. He said the grout sets faster than thin-set and provides less chance of heavier shelves (which mine are) from falling and damaging the tub before cured. He assures me he's demoed a test to prove the concept and fixtures adhered with grout in place of thin-set were as hard or harder to remove than those adhered the traditional way with thin-set.
Any pros ever heard of this method before? Is it valid, or should I insist on thin-set to adhere shelves to the walls?
Thanks in advance.
ghutch is offline   Reply With Quote
Old 11-16-2013, 05:54 PM   #2
Rewards Points: 2,240
If you are talking about adhering the soap dish/shelves with grout -
to cement board.
Nice trick! -
Don't know anyone who would do that.
Wait to see what someone else says!
rossfingal is offline   Reply With Quote
Old 11-17-2013, 09:48 AM   #3
firehawkmph's Avatar
Rewards Points: 1,922
I don't know why he wouldn't want to use thinset. As far as the soap dish or shelf falling, that's what they make duct tape for.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
jaydevries (11-17-2013)
Old 11-17-2013, 12:44 PM   #4
Rewards Points: 636
i am a thin set guy
just check your shelf manufactures instruction
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 11-18-2013, 09:54 AM   #5
Rewards Points: 3,130
"Trick" or not, I'd never put up shower shelves with grout. I've heard of some dumb things, and that one makes the list.
The Following User Says Thank You to md2lgyk For This Useful Post:
rossfingal (11-19-2013)
Old 11-22-2013, 09:45 AM   #6
Dark Knight
Streeter1981's Avatar
Rewards Points: 18
Send a message via AIM to Streeter1981
I hung up four shelves in my shower during my remodel, and used thin-set as per the instructions. Then of course grouted the gap in between the tile and the shelves after the thin-set cured.
Those shelves are not going anywhere, that's for sure, and it sure seemed to be the right way to do it as they were going in!
I'd stick to thin-set ... if you want the shelves to stick.
Streeter1981 is offline   Reply With Quote
Old 11-24-2013, 10:27 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Ceramic fixtures can be installed using unsanded grout. But do not try it with sanded as it has less "sticky" to it. I often used to set fixture that way especially when doing a tub enclosure. I'd set the soap dish and towel bar set after grouting the walls so they were not in the way. Works great, especially if you make a few holes in the backer for the grout to anchor.
However most people want corner dishes these days and I think it would be difficult to leave the proper space and still get the corner dish in there. So they're installed with thin set as I set the tiles. Keep the fixtures dry and tape.
So, are you talking about straight shelves or corner shelves? Sounds like corner shelves from your posting. Is he gonna mix unsanded grout and set them while installing the tiles?
Is he using regular thin set mortar that comes in a bag? What waterproofing method is he using?
Jaz
Tiling a Shower thinset question Dangchores Tiling, ceramics, marble 3 03-01-2012 03:04 PM
How to install Granite Shower Shelves dave-diy Kitchen & Bath Remodeling 12 11-25-2011 04:08 PM
waterproof shower grout Captflx Plumbing 11 03-13-2011 09:21 PM
Hairline crack in shower floor grout. Should I care? wsutard Tiling, ceramics, marble 11 11-21-2010 07:57 PM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 08:49 PM
