Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-12-2008, 06:21 PM   #1
ok - maybe I'm in the wrong place
I realize its DIY and I want to hire someone. Can anyone recommend a place/forum to get info on replacement windows and how to choose a good installer?
Where would you want your sister to go for info?
I'm confused by it all.
jamie is offline   Reply With Quote
Old 02-12-2008, 06:45 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
Here are few a sites regarding window information:
http://www.nfrc.org/
http://www.efficientwindows.org/index.cfm
http://www.jdpower.com/homes/ratings...ndow/index.asp
As far as an installer?
It might help to post the area you live in.
- Build Well -
Old 02-12-2008, 09:12 PM   #3
Thank you - I'm in Atlanta
Old 02-14-2008, 08:54 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
To find an installer.
Ask friends and relatives if they have any references.
Get at least three quotes for identical installs. You can tell a lot about the company planning to do the work by the quality of their estimate, their professionalism, etc.
one online resource I have had luck with is Service Magic. http://www.servicemagic.com/
Brik is offline   Reply With Quote
Old 02-14-2008, 09:24 PM   #5
newer than a newbie...
We had a small window installation company that told us outright that they are competitively priced (not the cheapest), and they wouldn't even give us a volume discount if we did more windows. This is a sign that they were not out to make a quick sale with cheap installation.
They mentioned 2 main types of window replacement:
1) Retrofit, where they install the windows in the existing frames (actually making the new window installation a bit smaller and suseptable to air leaks)
2) Brick to brick, where they gutted the entire window frame and re-built it.
They said brick to brick would allow them to properly insulate and lay out the window - and do it right. It cost a bit more but it was worth it. For our upstairs windows that were terrrible from the original builder 10 years ago, we've done all the windows over the last 3 years.
Definitely, get references from friends, but if you find an installer that 'teaches' you something about installation before just doing it or pushing it, you probably have made a right choice.
Good luck.
mcvane is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
J-channel on drywall edge, do I glue or just put in place yummy mummy Building & Construction 14 01-29-2008 05:10 PM
Ants and avoidance of baits - what am I doing wrong!? joeyboy Pest Control 11 01-14-2008 10:09 PM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 09:42 PM
Useing 20A receptical in place of a 15a Doug Crf Electrical 7 04-28-2006 09:23 PM
