Non-standard Door Frame - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-19-2015, 02:48 PM   #1
Question
Non-standard door frame
Bathroom has been gutted, getting around to the door frame and thought it best to ask the professionals before I screw the next thing up.
The house has plaster over drywall. The walls were removed in the bathroom (both plaster and drywall) and replaced with just drywall (1/2"). Outside the bathroom there remains the 1/2" plaster and 1/2" drywall.
The bathroom door frame measures at 5" (1/2" drywall on the bathroom side, 1/2" drywall and 1/2" plaster on the other side, 2x4 framing).
My understanding of this is, I should go above 5" on the door frame - I'm not sure if this is correct or not, or how much more I should go (1/4" or 1/8" for example). Trim would of course have to line up with the frame and such when completed.
Menards tells me this is a special order item - doesn't surprise me. Any suggestions?
deklar is offline   Reply With Quote
Old 04-19-2015, 02:53 PM   #2
Rewards Points: 14,294
Whole lot cheaper to just make jamb extentions for a standard door.
Google it.
Old 04-19-2015, 03:10 PM   #3
Google it.
Only thing with that, I'd rather not do any staining if at all possible. I have so much to do, it would save me a lot of time if I could find pre-stained and matching door frame/door and matching trim.
Unless I could use trim for the extension, I'm not sure.
Old 04-19-2015, 04:24 PM   #4
Now your asking for the imposable.
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
crown molding sloping wall and standard wall Alex007 Carpentry 12 03-13-2010 08:56 AM
Well Pump wiring with standard control box plumbdoc Plumbing 8 02-04-2010 09:27 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 05:01 PM
