Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-04-2007, 08:45 AM   #1
non pocket sliding doors?
id like to have a pocket french door between my living room/dining room and my kitchen. i cant install one though because i have ductwork and outlets on either side of the door. i really dont want to do a traditional hinge. i found this product, anyone use it? i can set it up to slide behind my fridge or behing my cabinet in my dining room. almost as good as a pocket door, but not quite as cool looking. http://www.johnsonhardware.com/2610f.htm
jamesdart is offline   Reply With Quote
Old 02-04-2007, 08:47 AM   #2
if you are curious, of the 4 walls, i can make it slide over 2. the right side wall has light switches and a duct inside it that supplies upstairs, but on the kitchen side of that wall there is nothing. the door can slide there. the left side wall has a duct in it that supplies the kitchen but on the dining room side i can slide the door there as there is only one outlet, that we dont use. so instead of 4 options, i have 2.
Old 02-04-2007, 09:43 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks for sharing your info.
- Build Well -
Old 03-07-2009, 05:48 PM   #4
Did you or anyone else try these doors? http://www.johnsonhardware.com/2610f.htm I think this is just what I've been looking for but would like others' feedback. Has anyone found similar better hardware?Thanks
Lind is offline   Reply With Quote
More On This Topic
Hi I'm Betty Ingham and speaking on behalf of Expert Village and I would like to give you a little of information on decorating a Victorian kitchen. These are the walls this is what the walls look like before we ever even sheet rocked and we thought it... Read More »
Kitchen Door High Fives
Kitchen Door High Fives by Expert Village
Alright., so, the next five that we have lined up for you. It's called the Kitchen Door; the front to back also known as the kitchen door. One of the most unique things about the Kitchen door is that it has a very high trust factor involved. If you don't... Read More »
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
Multiple Dog Greetings
Multiple Dog Greetings by Expert Village
Often times with multiple dogs in one house it could make coming and going a little bit more stressful, a little bit more activity among the dogs so it is always good to develop a routine that you got so you can separate dogs when you leave that when you... Read More »
Hello! This is Ross on behalf of expertvillage.com. That is my kitchen door and it is dark outside, it really doesn’t matter I cannot see the garage door anyhow if it was light out because it is blocked by the wall here. I did have to get up to... Read More »
sliding interior doors? jamesdart Roofing 4 02-06-2007 10:15 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
Sliding Glass Doors Drewimus General Discussion 2 10-02-2006 10:06 PM
Pocket doors ? burita General Discussion 2 01-08-2006 10:38 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 08:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
