-   -   No ventilation in bathroom, suggestions? (http://www.diychatroom.com/f15/no-ventilation-bathroom-suggestions-99214/)
LeviDIY 03-22-2011 05:33 PM
Hi all, embarking on my second bathroom renovation, project details are available here (http://www.diychatroom.com/f49/condo...looring-98814/).
I'm in a garden-style (4 story) condo complex built in 1980. A serious design flaw is that the bathrooms (and wash/dryer utility rooms) were all built interior, with no windows. Further problem is that there is no exterior ventilation for bathroom fans.. they simply "circulate." FURTHER problem is that the HOA/Condo association will not allow me to puncture the exterior structure on the side or roof, meaning no building of ductwork.
I've spoken with management about what others have done in remodeling (we've been here 3 years), as I'm sure people are running into the problems we are having.. and they say "well, leave the door open and open windows in adjoining rooms."
Sorry... if you checked out the link to my post on the project, you'll see the mold issue we are having.
SO... other than venting up into space between floors (this does nothing but complicate things for me later on or my neighbors, and is probably not to code)... the only thing I've thought of is a dehumidifier.
Problem is, this is directly off of our master bedroom, and those things are loud SOBs...
I found this on Amazon.com, with some pretty good reviews, wondering if you all have had experience:
http://www.amazon.com/Eva-dry-Edv-22...f=pd_sim_hpc_3
Also wondering if there are any "built in" models you've seen, as I'd like this to look finished, not "temporary," as it certainly will require to be on and connected most of the time. I was googling a bit to see if there are integrated models with bathroom fans/lights, but couldn't find anything.
Or, any other suggestions, besides mounting a revolt on the HOA?
LeviDIY 03-22-2011 05:52 PM
Via GBR in WA on another thread(http://www.diychatroom.com/f2/bathro...an-code-89843/):
M1507.2 Recirculation of air. Exhaust air from bathrooms and toilet rooms shall not be recirculated within a residence or to another dwelling unit and shall be exhausted directly to the outdoors. Exhaust air from bathrooms and toilet rooms shall not discharge into an attic, crawl space or other areas inside the building. http://publicecodes.citation.com/ico...007_par001.htm
Grrrrrrrrrrrrrrrrrrrrrr........................... ............:censored:
Ron6519 03-23-2011 04:23 PM
How do you vent the dryer?
Ron
LeviDIY 03-23-2011 04:27 PM
Ron - short answer: we don't/can't.
Longer answer: the only thing we can do is take the dryer vent duct and put it into an indoor dryer vent thing
(http://www.improvementscatalog.com/h...ryer-vent.html) which also adds to a mold problem in the utility closet... which, guess what, also houses the heat pump blower, which we've had to clean a few times already from mold).
Other owners in the complex have purchased a type of dryer that doesn't need to vent, but those are very very pricey.
Jim F 03-24-2011 09:52 PM
What about one of those portable A/C units witha 4" vent hose and window adapter? If you can set that up somehow so it will draw the air out of your bathroom and out a window that might work. What sort of a building has no exterior ventillation for the units? How do the other owners feel about this? And, what do they do to prevent mold? How many other owners are there? Maybe the owners can petition the HOA to have ventillation put in through the roof or an outer wall.
LeviDIY 03-25-2011 01:19 PM
1 Attachment(s)
@Jim F - thanks for the suggestion.
As you can see below, the bathrooms are interior and not even near a window to run that tubing, let alone the asthetical concerns.
Attachment 31236
Your HOA suggestion is a good one... quite frankly I have no idea what other people have done (there are 300+ units/owners). They have all had to have this problem.. and that leads me to some scary probable outcomes of venting into cavities between floors, lotta mold issues, etc. :furious:
I imagine a lot of people would be weary of special assessments, and quite frankly, I don't know if I have the time/energy/committment to fighting all that.
For now, a portable, somewhat quiet dehumidifier (like the one linked above) seems to be my own option, unless there are any more suggestions out there?
Jim F 03-25-2011 09:26 PM
That sounds like your best bet. Better the noise than mold. It can probably be shut off when you are sleeping anyway.
LeviDIY 04-10-2011 06:21 PM
As an update, posted this new but related thread: http://www.diychatroom.com/f15/mold-...needed-101090/
danrb007 04-10-2011 06:55 PM
Is there a unit above yours? If not is there attic space? I would apeal to the HOA to allow you to vent the bathrooms and dryer out the roof. Mold can be a health hazard. Have you checked with your insurance they may cover mold damage and when they hire a contractor to mitigate the contractor may be able to update it to code. Does your furnace have a fresh air intake from the outside? I know in Wyoming if you do anything with the furnace requiring a permit you have to add a fresh air supply from the outside if there isn't one. Just some thought to force the HOA to allow you to vent.
LeviDIY 04-11-2011 07:06 AM
@dan - there is a unit above me.. a pretty large crawl space, and I've *THOUGHT* about venting into it... but that just diffuses the moisture issue over a wider area, and just isn't right... although there is concrete below her floor above me. I called my insurance company and in a condo its different.. I dont know, was very confused, and I guess its too late now as the evidence is in the county dump :)
The HOA's standard response is: "you are not allowed to puncture the outside walls of the structure" - meaning no ventilation.
I've certainly seen contractors in the complex, and I know many have renovated bathrooms, etc before, so I'm assuming NO ONE is building to code. I simply do not understand this.
I'm documenting everything, taking pictures, and when I have the time, plan on compiling everything, going to the HOA first to try to get something passed, and if not, might have to goto the county inspector?
Blondesense 04-11-2011 11:29 AM
In your place I'd be tempted to reverse your plan. Go to the county inspector first, then to the HOA. I don't know codes, but I suspect since your place was built in the 80's the requirement may have been to have either fan venting to the outside or a window.
Talk to an inspector. Maybe as a hypothetical situation if you don't want to jump in with both feet. I suspect yours is not the first time restrictive HOA rules have clashed with building codes.
Get a county inspector behind you saying the place was not built to code and you may find a lot more leverage with your HOA. I can't imagine HOA requirements could trump building codes.
Edited to add:
BTW, does your project require a permit/inspection? If so, they may fight your battle for you.
LeviDIY 04-11-2011 12:07 PM
I'm chosing not to go that route. I'm not moving fixtures/electric, redoing faucet for shower.. and just prefer not to :) But you do have a point, and perhaps a call over there "hypothetically" would help in the ammo. Maybe somehow the HOA has an exception, which would be good to know going in.
criveka 11-01-2011 03:37 PM
bathroom ventilation
I have a small bathroom with no window and it had no heater. I had a small cadet heater installed in the bathroom and keep it on a timer so that it drys out the moisture and helps prevent mold and mildew.
A dehumidifier is also helpful for those who try to make their bath room a sauna! Most bathrooms are not made for long hot steamy showers so get your heat on, leave the door open if you have to and enjoy the reduction of moisture on your walls and floors. Hopefully the mold and mildew will be greatly reduced if not elimnated altogether.
The cadent heaters should be installed by a certified electrician.
Hope this helps you.
jen_mom6 06-23-2012 03:52 PM
Find an answer?
We recently bought a home that has many add ons here and there. The bsement is a walk out on one side, on another side of the 3 rooms only one has an egress and the other two sides have no outside access or exposure. That is where they chose to put the half bathroom. We don't have to worry about moisture from a shower but it sure stinks! I was wondering what you came up with for your problem in hopes it may help us.
In our old house we needed to replace the vent hose for the dryer that ran under the house. It was going to be a while before hubby was going to be able to get under there to do it so I found an "indoor" vent system. It is a box that you have in your house and hook your dryer hose to it. Add some water to the bottom and it catches the lint, the moisture comes back into the house. It was rotten. We had to have the dehumidifier on all the time! Cost loads, our power bill was hidious! I saw the dehumidifier mentioned a couple of times but from experience, that is not a long term solution.
Any more from your HOA?
mary hennessy 04-14-2015 05:20 AM
mary hennessy - bathroom ventilation and clean air.
Hi, we have a basement bathroom and have the same problem. Our walls are three foot thick and the only pathway we have found means that condensation will run back down into the electrics and therefore too dangerous. But!! I have been looking at air sterile purifiers which extinguish the source of the smell and clean the air and some of them are silent. They are used in care homes and hospitals as well as food places. In the absence of anything else I am going to try out one of these. They cost from around 150.00
