Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-25-2007, 01:23 PM   #1
night mare ceiling
please any advice would be good.chimney breast removed out of bedroom.new plasterboard in gap.remainder of ceiling artex.yuk.how do i get a nice smooth finish.please help
beth is offline   Reply With Quote
Old 04-25-2007, 01:33 PM   #2
They're all fixer-uppers
J187's Avatar
night mare ceiling
First thing you need to do is figure out whether or not your artex ceiling is asbestos - if so, you dont' want to just go scraping it away. If not, I would imagine you should be able to scrape it away, or rerock the ceiling with 3/8 drywall.
J187 is offline   Reply With Quote
Old 04-25-2007, 01:41 PM   #3
Question
night mare ceiling
thanks for advice.not asbestos.whats best way to remove artex.
Old 04-25-2007, 02:07 PM   #4
J187's Avatar
night mare ceiling
Your "huh" smily seems to indicate that you are somewhat taken back by my suggesting that it is possible that it is asbestos on you ceiling ... To my knowledge, unless your ceiling was constructed in the 90s or 2000s, the ONLY way to tell if your artex is asbestos is to have it tested. I could be wrong. This probably wasn't the best place to post this, quicker response probably would have come in other sections, but I'm sure some of the pros will weigh in soon. But providing its safe, I believe it will respond to wet scraping - but again, see what the pros say.
Old 04-25-2007, 02:32 PM   #5
night mare ceiling
sorry was not dismade at the suggestion of asbestos but at the thought of how to get the artex off.thanks again for your help
Old 04-25-2007, 02:48 PM   #6
J187's Avatar
night mare ceiling
Oh, ha. I agree about the "yuk" factor too. Unfortunately, I think it was pretty common in older homes to use asbestos in Artex and rerocking might be your safest and easiest route and even then I'd wear a mask if I ever drilled into the ceiling for anything. I will post in another section asking for pro assistance.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
