New Windows & Siding? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 06:57 PM   #1
Rewards Points: 358
New windows & siding?
We are having new windows professional installed, after the new windows are installed my plan was to replace the siding and trim. Is there anything I can do to in advance to the window install to insure that my siding install goes well?
Example should I tear off existing siding around window fame to make sure installer sets window correctly? (to the correct depth and doesnt try to install over top of layers of siding or trim)
Just planning ahead, I have never installed windows, and with the company I am getting windows from I am getting install basically for free, plus no interest financing..
Thanks!
cbzdel is offline   Reply With Quote
Old 07-17-2010, 12:47 AM   #2
Registered User
Rewards Points: 5,256
Newer house? Older house with wood windows now? Are they pulling the old frames (jambs,sill,and head)? Or just using replacement inserts? Is there a nailing fin or not? Metal windows now? New vinyl ones? Are the exterior walls in need of blown-in insulation? Existing siding type? New type? I'd do the siding with the windows, to get good waterproofing, same time.
Welcome, neighbor. I'm off 6th and North Sprauge.
Be safe, Gary
Old 07-21-2010, 04:55 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I agree with GBR, ideally having them done at the same time will produce the best results.... and BTW, nothing is "free".
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
copper "roof" to bay windows stained siding.. diy'er on LI Painting 10 04-24-2012 09:48 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
