New Window Vinyl Problem - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 05:47 PM   #1
New window vinyl problem
Help - I cut the hole too large in the vinyl, now there is a gap all around the window - how do I seal and fix it so the siding doesn't get water underneath without it looking too ugly please?
ballet6ft is offline   Reply With Quote
Old 01-16-2011, 09:10 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
pic? you would most likely use j channel
Tom Struble is offline   Reply With Quote
Old 01-17-2011, 08:04 PM   #3
The hole got too big because you couln't get the window flanges behind the siding, right?
If the necessary anyway J channel isn't big enough, maybe install brick moulding around the window, then the J channel around that. If you do make sure to install a piece of
1 1/2x 1 1/2" drip edge over the top. -Up behind the siding and out between the moulding and the J channel.
Dwoodsmith is offline   Reply With Quote
Old 01-22-2011, 05:21 PM   #4
Drywall contractor
Rewards Points: 1,070
You COULD replace the pieces of siding that are cut too short IF you can match the color. It is a pain and will be the more expensive route. The brick mold idea sounds feasible, but the one window will be different than the rest of the house. If you go that route, use the composite trim, not wood, so you don't have to worry about it rotting.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Lowes Reliabilt 3500 (Atrium 8700) a decent vinyl replacement window? lffisher Building & Construction 2 08-24-2010 06:55 PM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 07:24 PM
drilling sash on vinyl window rtoni Building & Construction 1 08-05-2008 04:55 PM
asbestos problem with vinyl flooring darsunt Flooring 6 08-31-2007 02:47 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
