Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-25-2007, 11:24 PM   #1
New member
New vented skylight in existing roof
Hi all, we are going to install a vented skylight in our bathroom. We have a wood frame house, with comp shingles. The roof is about 5 years old, and was done with a complete tear off, so it is only 1 layer. he roof was done with new sheeting, 1/2 OSB . The roof is on less than a 20* angle and we are in Northern Cal, our location never gets snow and the weather is mostly mild.
Here is my question, which is better suited for installation in an existing roof, a deck mounted or curb mounted skylight.? I looked all over the Velux website and could find no reccomendation.
I am leaning towards the curb type, If I remember correctly you can weave the flashing into the shingles then build the curb, then mount the skylight.
Is this correct? Any suggestions would be helpful.
Thanks for reading this,
Mikey
lightninrodman is offline   Reply With Quote
Old 07-26-2007, 07:47 AM   #2
Either style will work. It all depends on the quality job that is done on the flashing. I would install ice/water shield below the flashing/shingles and extend it about a foot or more around the perimeter of the opening.
redline is offline   Reply With Quote
Roof over existing roof Rammertime Roofing 9 05-25-2011 09:09 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
