New Range Hood - Duct Help - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 10:40 PM   #1
New range hood - duct help
Hello all, hopefully someone has a fix for this. I recently took out a microwave vent combo that was mounted above my stove, my problem is that the new hood I bought to replace with doesn't line up with the duct. The duct is almost right up against the wall, while the louver on the new hood is about 2" from the back of the hood. Pictures should help if this doesn't make sense. Help me out guys!
Looking up from stove.
Hardiw1 is offline   Reply With Quote
Old 08-31-2011, 10:04 PM   #2
Rewards Points: 5,336
You'll cut a new opening and either readjust the ductwork or replace it.
Ron
B. Franklin 1759
Old 08-31-2011, 10:22 PM   #3
Is it possible to adjust the duct over without affecting the roof vent? How would this be done?
Old 09-01-2011, 07:40 AM   #4
Hard to tell you without seeing the situation. If the duct run up to the roof is more then 3 or 4" , you should have enough wiggle room to shift the ducts. But since the shift is so small, you'll probably need to fabricate the transition piece yourself with sheetmetal.
Ron
B. Franklin 1759
range hood duct NealTX HVAC 6 08-14-2011 01:12 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
range hood duct problem orka HVAC 0 04-26-2011 08:18 PM
Duct tape for Range hood duct DIYGST HVAC 1 01-04-2009 06:46 AM
Range Hood Duct Size BOUTYM Appliances 2 12-20-2008 07:34 AM
