New prehung door threshold too tight against sweep
I just installed a prehung Masonite exterior door and everything seems fine except that the sweep is too tight against the threshold making opening and closing the door difficult. There are no screws on the threshold so unfortunately, I don't think that it is adjustable. I have an even gap around the whole door/frame.
Any suggestions to rectify this? |
You probably should speak with Masonite customer service or the store you purchased it from, it could be that the wrong weatherstripping was installed at the factory. It's difficult to say what can be done especially since there is no adjustment available on the threshold.
Check the latch at the striker to see where its hitting. If not dead center, one side jamb may be lower than the other. If centered, the door may be defective, as mentioned. Was the sub-floor tilted front to back so one edge is higher than the other? Not jamb to jamb but inside to outside. Some pictures would help.....
Gary |
Try a little vegetable or mineral oil on the sweep.
I e-mail Masonite about it. They had me test whether a sheet of paper could be slid without tearing with the door closed; I tested, it slid with resistance. Their response:
If the sweep doesn't "relax" I may just take the door off, take the sweep off and put on an aftermarket one that is slimmer in profile GBR: Latch is hitting striker nice and center. The subfloor ever so slightly descends towards the door but its very very slight. |
Ours does that too, masonite w/ a half-lite. Installed it in the summer, still hasn't really loosened up. Sort of glad to hear it's not just me, and I'll probably do the same (aftermarket sweep)
Before replacing the sweep, try a longer screw in the top (or second down) inside hinge screw hole to grab the framing and slightly lift the door, until the sweep wears down some.
Gary |
i've run into this too,my advise would be to pull the door and install an adjustable threshold that can be adjusted over time,most times the door slabs are are installed in their frames by a second party and many times they are installed pretty shabby
Any final solution to this problem? Just installed one of these doors today and the bottom sweep is very tight. You can only adjust up..not down. Has you door sweep "relaxed"?
Really need to go back and add you own post not add onto someone elses.
If you have an adjustable threshold and want to adjust it down you have to back off the screws and tap it down with a rubber mallet or a hammer and a piece of 2 X 4. |
Why can't you just remove the sweep, trim a little off the bottom of the door, and reattach the sweep? As little as 1/8 inch might be enough.
| All times are GMT -4. The time now is 12:49 AM. |
