Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-20-2007, 12:24 PM   #1
New office in the basement
hello all,
I am looking for a bit of advice on moving my office down to the basement. The previous owner built a room in the basement to be used as an office but didnt finish it before selling. The office is againest the outside wall on the back, is open to the basement on the left and front and makes up on of the wall for the basement garage/work shop on the left. The heat/air run thru the attice so I do not have that in the office until i can purchase a unit strictly for the basement.
my question would be, what all can i do to make the office safe to put some epensive electronics in without having to wory about moisture, hot cold, etc? I can go back and insulate the rooms walls and then do whatever else is needed, but i just want to make sure my computer and files and paperwork will be ok.
thanks
sleepy23 is offline   Reply With Quote
Old 08-21-2007, 01:32 PM   #2
A heat source. Complexity varies with your budget. Simple and safe would be those oil filled radiators you plug in. You can do electric radiant, or hot water radiant with a stand alone ventless hot water heater. Choices are wide and varied.
Ron
Old 08-21-2007, 04:25 PM   #3
so what do you think about the electronics and such? I currently have some quite expensive hobby stuff in there and the electronics seem to be fine...
Old 08-22-2007, 12:19 AM   #4
You want the electronics in a controlled, ie heated environment. A cold room can lead to condensation on the metal parts. Water is not a friend to these items. The room is heated whether you're in it or not, just like the rest of the house.
Ron
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
