Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-27-2009, 08:41 AM   #1
Question
New and need help w/ window stool
Hello: I'm Chuck:
I need help w/ cutting a window stool. I put in a window and can't figure out how to cut the stool to match the angle. (The piece that goes up against the window from the inside above the apron) I know there is a jig for a router to do so, I haven't been able to find one.
Thank you.
Fingersallacct4 is offline   Reply With Quote
Old 08-27-2009, 10:37 AM   #2
General Contractor
Use your table saw to cut the correct pitch or angle. Then cut it to size and notch it accordingly. That's the easiest way I know how to do it. Most stools you would buy at the box stores usually have a 15 or 22.5 degree angle already cut for you.
ARI001 is offline   Reply With Quote
Old 08-27-2009, 04:31 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Fingersallacct4 View Post
Hello: I'm Chuck:
Thank you.
Use an adjustable T-Bevel.
Examples:
http://cgi.ebay.com/ADJUSTABLE-SLIDI...51510003r23016
http://screwdriver.net/stanley-46825...astic-t-bevel/
How to use one, to figure out an angle:
http://www.ehow.com/how_2081062_use-tbevel.html
- Build Well -
Old 08-27-2009, 06:43 PM   #4
Moderator
http://books.google.com/books?ei=8h0...G=Search+Books
Be safe, G
