New Help Finding Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 02:27 PM   #1
New help finding door
Odd application, but need help finding a door with the following criteria
Easy part:
Double door - 60 inches wide ideal
Outswing
Exterior application, but doesn't need to be insulated
Need a lock, deadbolt is preferred
6 panel is preferred design
Would like prehung so I don't have to mess with it
I get snow/rain here so need it to seal reasonably well
Tough part:
Height is a huge issue, would like a door no taller than 6 feet.
The shorter I have found so far is 76 1/2" (79" RO) for a whopping $700
TANC is offline   Reply With Quote
Old 01-15-2010, 05:02 PM   #2
jlhaslip's Avatar
Rewards Points: 2,882
sounds like a custom-built door set.
find a capable carpenter/cabinet guy in your area.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-16-2010, 06:00 AM   #3
A double cut down door for $700 is not whopping. Many lumberyards have on site door shops that can easily do a 79" door opening. Steel doors will be the least expensive, but fiberglass is better from a maintenance standpoint.
Old 01-16-2010, 07:34 AM   #4
700 was whopping to me, when i can get a standard height in the 300-350 range
Old 01-16-2010, 07:42 AM   #5
soon as you vary from the suppliers norm up she goes
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
