New Deck Where There Is Cement Step - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 08:14 PM   #1
Question
New deck where there is cement step
We are planning a deck. An old solid cement step is in the way.
If we build over the top of this step, would that be up to code.
What problems could this cause?
This cement step is lodged slightly under the siding. It will have to be pulled out and inch or two. We would have to
borrow a bobcat tractor with a jack hammer to break the cement. So if we could build overtop that would simplyfy the job.
Shurl is offline   Reply With Quote
Old 05-02-2012, 12:05 AM   #2
Rewards Points: 2,212
Talk to your local inspector. Here it is legal, just may look dumb under the deck, can see it through the boards.
mae-ling is offline   Reply With Quote
Old 05-02-2012, 06:15 AM   #3
Yep, here too. Just cut the joists to fit around the step. Add 2x bridging between the joists at the step.
Old 05-02-2012, 07:49 AM   #4
Rewards Points: 13,994
Sure would be nice if you could post a picture so someone could give better suggestions.
mae-ling (05-02-2012)
Old 05-02-2012, 03:52 PM   #5
Thanks everyone,
Just talked to a building supply center. They said there wouldn't be room to put the floor joists or floor boards.
The step will have to come out.
Old 05-02-2012, 07:04 PM   #6
Go rent a big jack hammer from Home Depot. Or any retal place,
Old 05-09-2012, 12:19 AM   #7
Rewards Points: 324
You only have to get it low enough for the joists to go over the top. My house had a set of concrete steps in front, 3 hits with a sledge hammer & they fell apart. Had to remove them because they were in the way of shifting the house.
mgp roofing is offline   Reply With Quote
Old 05-11-2012, 03:30 PM   #8
Rewards Points: 1,300
Please post us a picture of the area. Are the steps solid or are they the hollow precast steps sold thru concrete and landscape centers?
danpik is offline   Reply With Quote
Tags
build deck , remove cement
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Leveling a deck denemante Building & Construction 10 08-24-2010 08:11 AM
Movement of cement pool deck around inground pool sgagnier Landscaping & Lawn Care 1 07-05-2010 12:31 PM
Leveling cement -step down porch with rest of house Cathy2 Flooring 1 05-24-2009 05:15 PM
