Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-23-2010, 05:27 PM   #1
DIY Expert in Training!
New Construction window installation questions
Tomorrow I am replacing a disaster window with a bigger "new construction" window. Currently the window is in a 2x4 wall with drywall type of sheathing and then foam board insulation. Because the crappy window wasn't sealed correctly I am replacing the sheathing, studs, and foam. In it's place I will put up 1/2" plywood and foam board.
My questions:
1) After I put up the plywood...do I put tar paper on before or after the foam? Or both?
2) Do I run the foam right to the opening or should I make a frame of 1x3?
Thanks!
gone_fishing is offline   Reply With Quote
Old 04-23-2010, 05:45 PM   #2
Solutions (handyman)
Not sure I totally understand your issue but here are the basics. Assuming you've removed the window and the opening is the same for the new replacement window, the new window should go in from the outside. Most new windows come with a pre-attached brickmold or nailing strip (to be screwed not nailed). The existing frame should be fine unless it became wet or damaged. On the inside, the drywall should be the first thing you see, then, underneath there should be a plastic vapout barrier, then your insulation. The insulation should be tight to the frame and the vapour barrier should be sealed to the frame so there is no air movement around the wall/frame area. There may (and should be) some room between the new window and the existing frame (about 1/4" all around). This allows for levelling and plumbing the window. Once the window is shimmed and where you want it, I'd suggest spraying "Great Stuff" , a foam expanding insulation, around the 1/4" gap.
Once that is done, your inside window casing should cover the gap area and your done.
Hope this helps.
Mark Harvey is offline   Reply With Quote
Old 04-23-2010, 06:04 PM   #3
Mark, you totally forgot the most important part - flashing the exterior.
Gone fishing, your window manufacturer will have detailed instructions on how they want you to flash the windows. Follow those instructions carefully if you want them to stand behind their warranty. Most window manufacturers have a website from which you can easily download the installation instrutions.
Old 04-23-2010, 06:20 PM   #4
I have gas!
Clutchcargo's Avatar
http://www.na.graceconstruction.com/...24_Guide-B.pdf
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-23-2010, 06:42 PM   #5
Jogr,
You're
Old 04-23-2010, 07:40 PM   #6
I know how the flash the window...thanks for the guide though...very good reference. The sheathing and studs are water damaged and have mold on them. On the exterior of the current sheathing there is rigid foam before the siding. My question was should I put tar paper over the plywood sheathing and/or over the foam. Next question, when I go to install the window do I nail right through the rigid foam or put a strip of 1x3 around the opening as a nailer?
Old 04-23-2010, 07:59 PM   #7
Tom Struble's Avatar
i would definatly put the paper over the ply,then either tape the seams of the foam or put a housewrap over it
you can nail the window over the foam
Tom Struble is offline   Reply With Quote
Old 04-23-2010, 08:09 PM   #8
I have gas!
Put plywood around the opening so that you have something solid to nail the window to. Then butt the foam right up next to the plywood. Of coarse the plywood (or whatever nailer you use) needs to be the same thickness as the foam. Don't nail the window to the foam board. You may want the nailer a little wider if you're putting up trim after the window install.
Old 04-24-2010, 09:51 AM   #9
Concrete & Masonry
Right on Tom, & I would add to the OP that I would suggest foil faced foam, as it's easier to tape seams on. New const. windows are installed over foam on new homes all the time w/o issue.
jomama45 is online now   Reply With Quote
Old 04-24-2010, 07:04 PM   #10
Update...I ended up putting plywood, tar paper with 6" overlap, foam board, tyvek with taped seams. I used 1/2" plywood around the window as a nail strip. Almost everything went smooth. I rushed my nailer cuts so I needed to trim them back so I could install the window. Pictures to come soon.
Old 04-24-2010, 09:09 PM   #11
[IMG]http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs486.ash1/26602_1433803562376_1151531266_31319426_5926787_n. jpg
[/IMG]
Window installation advice Cossack Remodeling 7 04-16-2010 02:44 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 11:26 AM
Window replacement Help (New Construction) gregt848 Building & Construction 3 10-18-2009 07:59 PM
Window installation cost only. Changeling Building & Construction 18 06-30-2008 03:01 PM
