Found ya'll today and read all the plumbing posts!!
I am trying to remove the tub drain stopper from the drain. It appears to be a lift and turn type which should just screw off, but mine doesn't have a set screw. I have tried pliers, but it only goes so far and then nothing. Any suggestions?
Also, I am thinking of removing the cultured marble wall surround and replacing it with either a 3 piece plastic type, or going with ceramic tile. Any thoughts on this?? The current surround is loose, and it looks like there is only sheetrock behind it. Would I need to remove the SR and replace it with green board??
