Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-19-2009, 02:15 AM   #1
New Bath Tub Framing
I want to put in a 60" tub but my opening is 66" long. I am planning to build a 6" frame on the far end of the tub away from the drain. I want to do it this way because there will be a hatch for access on the other end for the shower mixer. Is there a problem with building a box like this on the far end? I'm just concerned about drainage. I will slope it into the tub slightly and tile it.
Thanks.
jonathan03 is offline   Reply With Quote
Old 10-19-2009, 07:54 AM   #2
Remodeling Contractor
no problem. Be sure to waterproof under the tile and up the wall 12" also.
Old 10-19-2009, 10:19 AM   #3
What do you mean by waterproof? I usually use 1/2" cement board and thinset mortar under the tile. Is there something else I should do? Thanks.
Old 10-20-2009, 05:05 AM   #4
use you need to use a waterproofing membrane. Treat the ledge the same as you would a shower floor. Check out details on installing such items at the schulterer site.
Old 10-20-2009, 04:57 PM   #5
Moderator
Don't forget to insulate around the tub and grout under it, at install. Use tin to cover the drain cut-out in sub-floor if over a crawlspace to keep the critters out...... wait, that's my house.
Be safe, Gary
Clothes taking longer to dry?
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
recessed bath tub framing amakarevic Building & Construction 1 06-03-2008 11:11 AM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
