New Addition -help - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-27-2008, 02:38 PM   #1
Unhappy
New addition -help
We recently added an addition onto our existing house. When it rains, it leaks terribly on most occasions where the two meet. The addition was shingled and done properly, so we thought; it was a do-it-yourself-er. Any tips on what to look for, mistakes that may have been made?
susan
susan222 is offline   Reply With Quote
Old 06-27-2008, 05:23 PM   #2
It would be nice if you could add a picture or two of the work that was done. It would give us an idea of possible causes for the leak/s.
Handyman50 is offline   Reply With Quote
Old 06-27-2008, 07:10 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Leaks may develop from a variety of causes. They can come from a roof issue, things attached to, or passing through the roof, windows, doors, exterior trim issue, cracks, ice-dams, etc, etc, etc...
Water does not always travel downward in leaks. It can travel along, on top of, or under a section of lumber, within walls, along pipes, on top of heating ducts.
Thus, water may enter at one point in a home, and "appear" at another location.
When we are called to investigate a roof or exterior leak issue (we did ALOT of that this past winter), we investigate the exterior first, if that does not reveal an obvious intrusion point, then we investigate inside. Example: Roof leak. We enter the attic and investigate the underside of the roof sheathing. If a ceiling, attic, or wall area is inaccessible we remove drywall, and investigate the interior sides of the roof or walls. Water or moisture unfiltration generally leaves water stains. These are like following footprints to, or from, a crime scene. They lead you right to the source or area of a leak. If the area is actively allowing moisture intrusion, then we use a moisture meter to follow the trail.
Again, getting back to the point of water "travel" within a home; Realize that moisture leaks, 50% of the time, may come from areas that you may not suspect. We once encountered a leak in a basement, during a remodeling project. The previous home owners had replaced the slider door above the area, assuming that this was the moisture penetration point. We followed the path a little further to the 2nd floor, the 3rd floor, and finally to the roof. This also explained the new exterior paint work (less than a year old), that was peeling off. The Home owners needed a new roof. New roof resulted in both problems (Leak under door area, and peeling paint) being solved.
You may have to bring in an experienced pro to do a detailed investigation, otherwise, you are just guessing.
- Build Well -
Old 06-30-2008, 12:42 PM   #4
Sounds like a flashing problem
martyshel is offline   Reply With Quote
Old 06-30-2008, 02:42 PM   #5
leaking addition
Agree, it could be flashing. You really need to walk around when it rains and take pictures so you can attempt to follow the path. Here's an interesting article with picture of how flashing should be installed -- perhaps this will help.
http://www.oldhouseweb.com/stories/Detailed/10146.shtml
Allison1888 is offline   Reply With Quote
Old 06-30-2008, 11:50 PM   #6
New addition
Thank you for the replies. I will work on getting pictures of the job.
susan
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 10:43 PM
Question: second story addition to existing room elmorem@gmail.com Building & Construction 3 02-17-2008 09:38 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
