Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-26-2009, 02:29 PM   #1
Husband_dad_homeowner
Default Needing to widen doorway...help!
Hey all,
My wife and I are new homeowners and we recently had the opportunity to go buy a new washer and dryer. Well, the good guys over at Lowes got to our condo and we found out that our doorway to the bathroom where the machines are located, has a 24inch opening with the frame and jam on...wihtout it...maybe closer to 27"...we need more than 28" as that is the smallest width of our old and new machines.
ANy help wold be greatly appreciated...my wife in a rage took off the molding already...I think it might be best to extend it to the left now, if we're looking at the door from the side it opened, since there is some damage to the wall there, bt that's also towards the light switch. I think it would be easier to extend to the right since the closest wiring that way is the doorbell chime box, but I've never done anything close to construction or remodeling so this is all very foreign to me.
If the wall is easily...and I'm using that term very loosely with the lack of experience I have...repaired, should we extend to the right? Or should we extend to the left and just cut out the damaged wall?
Also, we're new parents and living on one income, so the least expensive route is preferred, no cutting corners, but if I can do this all alone with help from my wife, we're good, if not....we may be doing lanudry in the living room for some time.
Any help is greatly appreciated.
Thank you!
dgallagher is offline   Reply With Quote
Old 10-26-2009, 03:07 PM   #2
Not so new
12penny's Avatar
dg...go to user cp at th top of the page and finish your profile.
I think this is going to be way more involved than you had anticipated.
I'm confused as to which is left or right and a pic or two would really help.
Is this wall load bearing?
What tools do you have available?
Was your house built before 1978?
12penny is offline   Reply With Quote
Old 10-26-2009, 03:14 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
If its not a load bearing wall it is fairly easy
But easy can still be a pain
30" is the min door I will put in, prefer 32"
If its not load bearing you cut the studs/drywall out, put a new stud in & put the pre-hung door in
BUT - you need to be careful of existing wiring/plumbing that may be in those hidden cavities
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 10-26-2009, 03:27 PM   #4
Hi 12penny, thanks for the quick reply...
Alright, here goes,
I'll finish my profile, I'm at work so I'll try anyway.
I don't have pictures here today, but I'll try to get some for tomorrow.
I don't think it's load bearing as it come up short from actually extending the length of the condo. It goes to the bedroom and the living room, but there's no extension to either.
I have a very basic set of home tools purchased from Fred Meyers and access to some more at my inlaws, but not sure of what all is there.
I beleive it was built in 74.
When I say left and right, I'm refering to standing in the bathroom looking at the door, it would swing into the bathroom, and the knob is on the left. So to the left of the door, there's the light switch about 1 foot away and to the right, there is nothing for about 4 feet, it enters into the laundry area abot 6 inches to the right. On the outside of the bathroom, looking at the door. The right side is now where the light switch would be on the other side of the wall and to the left, there's about 4 feet and then living room and about 2 feet over and by the ceiling is the doorbell chime box.
I know there's not much info provided or any pictures yet, but your help is greatly appreciated and we'll take all the help we can get.
Thanks again!
dgallagher
Old 10-26-2009, 03:43 PM   #5
Not so new
12penny's Avatar
dg...I'd still feel better seeing pictures before we decide load bearing or not. Some of the bathroom side as well.
Old 10-26-2009, 03:46 PM   #6
Will do, I'll try to get my wife to send some pictures through the phone, if they show up ok, I'll post them, if not, we'll upload some tonight.
Thanks agian for you help 12penny and for the tips dave!
Old 10-26-2009, 05:55 PM   #7
Default some pics...
Here are some pictures, I'll pt some more up in a minute...
needing-widen-doorway-help-att393361.jpg   needing-widen-doorway-help-att393362.jpg   needing-widen-doorway-help-att393363.jpg   needing-widen-doorway-help-att393364.jpg
Old 10-26-2009, 05:57 PM   #8
Default ...more pics...
Here's the rest...if you need more I can upload more tomorrow...thanks for the help guys!
needing-widen-doorway-help-att393365.jpg   needing-widen-doorway-help-att393366.jpg   needing-widen-doorway-help-att393367.jpg
Old 10-28-2009, 11:51 AM   #9
Not so new
12penny's Avatar
dg...I think I'd go toward the vanity. Still cant tell if its a bearing wall. Please make sure before demo. Check ceiling joists for direction of travel.
Old 10-28-2009, 12:48 PM   #10
Thanks 12 penny, so, how do I tell if it's a load bearing wall? What should I do in regards to going towards the vanity as the light switch is in that direction? How do I check the ceiling joists?
Again, thanks for all the help!
dg
Old 10-28-2009, 02:39 PM   #11
Not so new
12penny's Avatar
dg....if you have attic access, do the ceiling joists run parallel to the wall or do they cross it. If they cross do the ends of the joists rest on it? Is that another interior wall accross the hall? Do the ends rest on that one.
Old 10-28-2009, 02:44 PM   #12
No attic access, there's maybe a foot of space between our ceiling and the outside, possibly a bit less...
Old 10-28-2009, 03:39 PM   #13
Not so new
12penny's Avatar
dg...you're probably okay to go ahead with what you want to do. Remove the old jamb. Remove the drywall from above the door and to which ever side you decide on, both sides. Which ever way you go, remove the jack stud then the king stud and finally take the header down. Go buy your door and make your opening 1/2" wider than the new jamb. This allows for shims. Install new king stud, longer header and finally jack stud. Hang your new door, drywall, tape, mud and call it a day.
Take it apart slowly and carefully, put it back together the same way.
And I'd still feel better if I knew which way the joists/rafters ran.
Old 10-30-2009, 09:18 PM   #14
Look out back to see where the rafter tails are: in line or perpendicular? If closed soffits, which way does the roof slope- side to side or front to back? Look under the house to see if said wall has a double joist under it- if so it is load bearing. If perpendicular to the floor joists, probably load bearing.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Tags
frame, interior door, new doorway, remodel, widen frame
More On This Topic
Children often need to convince their parents that they need a puppy. Sometimes, a husband may have to convince his wife that he needs a puppy in the house. Here is how you can convince your wife that you need a puppy. Read More »
In this clip, we're going to cover how to clean up your dialogue. Now you're familiar with movies that started off in the silent era which was very visual, and then in the late twenties, it went into the talkies and it was all about the dialogue, and if... Read More »
Tips on Gifts for Your Wife
Tips on Gifts for Your Wife by Expert Village
I'm Karina Fraley for Expert Village. I'm a lifestyle expert and I'm the official mom for the mommywood.com website. Today we are going to be talking about some gift ideas for your wife. Christmas is really a great time to show your wife how you love her... Read More »
My name is Tres Tew; I am an instructor here at Yu Shasasru Martial Arts. On behalf of Expert Village, I'm going to be showing you how to defend yourself with open hands against either rifles or shotguns. Now surprise can be a very key component when... Read More »
Buying a wedding gift from a registry is an easy way to pick out a gift to take to a wedding. You simply choose items from a list the couple has selected, so you can always be certain your gift will be well liked. Some people, though, like to find... Read More »
How to cut exhisting flooring in the doorway jjpar Flooring 6 03-06-2008 09:04 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 11:11 PM
Widen a doorway Oilerz Remodeling 3 01-06-2008 10:31 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 05:52 PM
constructing a hidden doorway bubblehd Building & Construction 1 10-15-2005 04:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
