Need Some Help With Remodel Of Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 09:26 AM   #1
Rewards Points: 77
need some help with remodel of bathroom
I have attached some pics, I am redoing the tile surround in the shower and laying a tile floor and other things. I am having some issues with starting the remodel of the shower area. I have tore down old tiles and drywall came with. Question 1- Should I rip out the rest of the drywall and go right up to the ceiling with cemet board or can I squaare off where I am now and transition the cemet board to the greenboard.
Do i need to do a vabor barrier for between the cement board and studs?
I am using 1/2" cement board and the exisiting green board is 1/2" also
bowanna03 is offline   Reply With Quote
Old 02-20-2011, 11:01 AM   #2
I recently built a new tub/shower surround, and did not run the cement board and tile to the ceiling. What I thought I was saving in materials ended up costing me hours of aggravation, and I would never do it that way again.
1910NE is offline   Reply With Quote
Old 02-20-2011, 11:47 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you aren't going to tile the ceiling then transition where you are and don't mess around with the wall/ceiling juncture. Once you tamper with the ceiling corner you run the risk of damaging the ceiling and having that to fix. If it ain't broke don't fix it.
I would eliminate the vapor barrier on the studs and use liquid waterproofing on top of the cement board.
What brand cement board are you using?
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
flashover600 (02-20-2011), littlecleo (02-21-2011)
Old 02-20-2011, 11:47 AM   #4
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Agree transition materials at corners. Cement board not guaranteed to be exact same thickness as green board. If tiling can hide transition if it its not too big a step. Big step you are shimming IF new material is thinner.
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 02-20-2011, 11:49 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Cement board thickness variance won't be that much if any. That isn't a major concern in a remodel like this.
XXX
Old 02-20-2011, 11:54 AM   #6
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Trust Bud, but I seem to run into Murphy a lot.
--Chris the DIY Guy
Old 02-20-2011, 12:06 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Chris...
If there were to be a variance in thickness in the wallboard it would be that the cement board was smaller. Hardibacker for example is only 7/16" thick even tho they sell it as their "500" product suggesting it is 1/2" thick. Since it is smaller it isn't an issue. That variance can be easily filled and feathered and if it is covered with tile anyway............
XXX
Old 02-20-2011, 06:31 PM   #8
Rewards Points: 77
I am using perma base from lowes. 1/2" thick and the exisitng green board is 1/2" thick. Another question is around the end of the sides I have no studs to screw too . What Can I screw to make it stable at the end?
Old 02-20-2011, 07:47 PM   #9
Rewards Points: 91
Add extra wood at the corners to screw the wall board to. Just be sure to line them up with existing studs.
George6488 is offline   Reply With Quote
Old 02-20-2011, 08:37 PM   #10
Agree, that's what we did on a manufactured home remodel......didn't have any studs to attatch the drywall, so we took 2x4s and attatched them to the studs that were hidden in corners. Or used brackets to mount studs.....
I hate manufactured homes!
flashover600 is offline   Reply With Quote
Old 02-21-2011, 08:07 PM   #11
Rewards Points: 276
You want to have studs spaced 16" on center for cement board otherwise it will flex too much. Somebody will lean hard on that wall and crack the tiles or grout.
Jim F is offline   Reply With Quote
Old 02-25-2011, 11:27 AM   #12
Rewards Points: 77
Well guys thanks for the help. I finished the shower surround last night. I will start to grout this evening. Next step will be the floor. I am going to use hardibacker. I am pulling up the linoluem tonight also. There is glue residue left over, Can I go right over the glue and old subfloor with the hardibacker or should I pull up the old subfloor. It is solid and no water damage and would rather not pull it up if I don't have to. I will post some pics later
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 09:59 PM
Bathroom Remodel - Wish I had done it myself JeremyEB Drywall & Plaster 12 02-07-2010 10:52 PM
Bathroom Remodel Questions Vikeologist Remodeling 52 12-31-2009 09:13 AM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
